Thats a nice looking cart. Im thinking of making some running gear for my TB302, and your cart was inspiration.
Results 11 to 20 of 42
Thread: Aluminum Welding Cart Project
04-24-2008, 11:30 PM #11
- Jan 2008
- In wal-mart
- 460
04-25-2008, 08:44 PM #12
I like it up high cause it will be much easier to adjust, and I have a storage area. I will strap the Dynasty down even though it's very stable. No play at all in the wheels or the carts frame. I'm still not done with it yet. I bought 1/2" x 1/16th x 3ft Aluminum tube today to make my cable hangers. I also bought the chrome chain to secure the tank. I have the weld the middle frame still
. Is there any thing else you would do to the cart?
usmcruz I'm glad I inspired you. I went to get a cart and realized it was to small so I decided to make one. You can do anything you can imagine with a welder. If you need any pics let me know. I getting good with this Pic stuff.
JamesLast edited by StillBoostin; 04-25-2008 at 08:46 PM.
Miller Dynasty 200DX SOLD
WeldTec Water Cooler SOLD
Miller Millermatic 180 w/ Spoolmate 100
20Ton press
And lots of Cut-off and grinding wheels
www.IAGPERFORMANCE.com
04-26-2008, 02:00 AM #13
Looking awsome dude
usmcruz: wanted to say thanks again for your pics from the other thread...
If you make a cart for your running gear, you still going to make it so you can put forks under it to put it in your truck???I'm not late...
I'm just on Hawaiian Time
04-26-2008, 07:50 AM #14
No. I think you got everything. I think you mentioned you were adding a handle..
Man that thing would so not work at my place.. Lol. I have to pull my cart out of the garage, over a 1" high water dam, off the concrete walkway (1" down) and into the grass where I'm currently working. If it weren't so low it definitely fall over. But you lucky b@stard, you actually have a garage to work in.
Miller Maxstar 200 DX
RMLS-14 Momentary Hand Control
Miller Syncrowave 180 SD
Porter Cable 14" dry metal saw
Hitachi 4.5" grinder
http://mhayesdesign.com
04-27-2008, 07:55 PM #15
I can't believe that foot pedal will work on that machine
Have you tried it??? That has to be the first time I've seen one like that on a Dynasty for sure.Last edited by FusionKing; 04-27-2008 at 07:58 PM.
Miller Bobcat 225 NT
Miller 30-A Spoolgun
Miller WC-115-A
Miller Spectrum 300
Miller Spoolmate 200
Miller 225 Thunderbolt
SPEEDGLAS 9100XX
04-27-2008, 08:00 PM #16
Not yet. Why would it not work. It is a 14 pin plug, and it lined up and screwed in. It has 6 pins in it I believe. The part number is RFCS-14 Remote Foot Control (14-pin plug).
JamesMiller Dynasty 200DX SOLD
20Ton press
04-28-2008, 01:15 AM #17
same one that came with my contractor's kit for my dynasty 200dx also! But...your's looks metal?
I'm not late...
04-28-2008, 08:05 AM #18
If it's 14-pin it will work. Ahh.. standards.
That is a monster pedal, though. I got a gigantic one with my Maxstar - it was a pain to lug around. So I switched it with the lighter plastic one that came with my Syncrowave.Miller Maxstar 200 DX
04-28-2008, 10:05 AM #19
Did you get a black soot covering or surrounding your weld?
Miller Maxstar 150 STL
Miller Millermatic Passport Plus
Thermal Dynamics Dragun Plasma Cutter
Protect your seccond ammendment rights! Join the NRA!
04-28-2008, 03:46 PM #20
20Ton press
