Page 1 of 5 12345 LastLast
Results 1 to 10 of 42
    Mar 2008
    Baltimore, Maryland
    315
    Default Aluminum Welding Cart Project
    ***NEW PICS ON THE SECOND PAGE*****
    I don't have everything for my new Dynasty 200DX YET! So I'm using my Spool Gun to weld it up. I just wanted to have super light weight cart to move around and stick in my car on the way to work site(aka friends house to weld). Here are some starter pics.
    Miller Dynasty 200DX SOLD
    WeldTec Water Cooler SOLD
    Miller Millermatic 180 w/ Spoolmate 100
    20Ton press
    And lots of Cut-off and grinding wheels
    www.IAGPERFORMANCE.com
    Mar 2008
    Baltimore, Maryland
    315
    20Ton press
    Salem ,Ohio
    3,953
    Cool
    Nice work...Bob
    Feb 2008
    North of Phila. PA
    404
    Looks nice. If you know it, what is the exact designation for the alum chanel you used? I'd like to use something like that for my ladder rack as opposed to a tapered leg C type channel. I've seen several other designations such as alum std or americian std but can't get any picts of what is what.
    Nov 2007
    dallas tx
    325
    ya know... id still make it weigh a ton
    my daddy always said i was IRONHEADED....
    feel free to P/M me
    Mar 2008
    Baltimore, Maryland
    315
    Quote Originally Posted by DSW View Post
    I got all my aluminum from a local metal supplier. It was all scrap pieces, so I got it cheap $30! Bought the Al tube from Ace's True Value $10. Steel round stock $10. Harbor Freight Wheels for $5.50 each on sale, and the castor wheels for $6.50. All hardware is grade 8(had it laying around).
    I add the vertical square tube, and a top platform. Will get more pics tomorrow.
    My Miller foot pedal came in today. It did come new like the guy said, but **** it is huge. How is the finger control? You like it or hate it. I'm a southpaw so which one will work for me?
    James
    20Ton press
    CT.
    333
    Nice, now hook that Dyn. up and start tiggin' aluminum on that cart.
    T.J.
    Miller Dynasty 300DX
    HTP MIG 240
    HTP 380 Plasma
    Bridgeport Milling Machine
    South Bend Lathe
    Etc. Etc....
    tjsperformance.com
    Austin, TX
    621
    Quote Originally Posted by StillBoostin View Post
    James
    http://www.millerwelds.com/resources...ad.php?t=12778
    Miller Maxstar 200 DX
    RMLS-14 Momentary Hand Control
    Miller Syncrowave 180 SD
    Porter Cable 14" dry metal saw
    Hitachi 4.5" grinder
    http://mhayesdesign.com
    Mar 2008
    Baltimore, Maryland
    315
    More pics.
    Will be bolting removable caps on the bottom of my 2x2 verticals, so I have a place for the welding rods seen in the pics. Will be adding an old jack handle(blue) as my cart handle on the front of my cart. Next, I will bend some tube and drill two holes in it to make hangers for all my cables. Lastly, I need to add a chain in the back to hold the tank on the back. I should have made it longer so I could have both tanks on the rear of the cart. Might add it later. If there is anything else you guy can think of let me know. Sorry can't hook it up yet cause I have to add a 220v outlet some where my mom can't see. No I don't live with my mom I'm 29. I just keep all my tools over there.
    James
    20Ton press
    Austin, TX
    621
    Wow. That's taller than I was expecting it to be. Have you tested to see how stable it is? Might want to throw a strap over the welder..? (Pointless if the cart isn't stable). $.02
