Results 1 to 7 of 7
    Dec 2006
    Wartburg,Tn
    575
    Question how to bend conduct without a bender????
    I need to know how to bend some conduct with no beder,I am building a mini-tricylce (modfing mini-chopper plans) using bicycle parts ,chain, pedals most of the stuff you would find on a bicylce
    the reason I`am building it so i can get pratice for building a mini-chopper with a motor
    I`am going to build a fake tank (using english wheel)
    Inferno Forge
    Chris
    Aug 2006
    near rochester NY
    9,881
    i have herd filling the tube with sand helps keep it from colapsing when bending but never tryed it.
    be shore to post pic's as the build progreses.
    Mar 2007
    511
    ive heard of the sand idea and u can tack some rebar or something on to sheet metal in a curved line shape and heat it as u bend it
    Dec 2006
    Alaska
    732
    The sand idea works great I use sand box sand from the local HIC
    you want the finest (smallest) grains you can get filler up don't pack it then bend a way you need to leave some room for the sand to move while bending
    TJ
    Jan 2007
    Montana, USA
    203
    I've had good results in bending EMT up to 2.5 inches OD by packing sand inside and capping the ends, then heating with an O/A torch and tweaking. In fact the bending went so well, I had to reheat and straighten a bit.
    Dec 2006
    Wartburg,Tn
    575
    Talking
    I try and post some pics during building it ,belive I will use the torch 4 this job
    Thank Y`all alot !!!
    Inferno Forge
    Chris
    Sep 2002
    Clark County, NV
    2,696
    You didn't tell us what size and wall-thickness of conduit you want to bend.
