Try to have this make sense...... for years when I've mitered
tubing at a steep angle I've always ground the "pointy ends"
(at right angle ) to the tubes axis. Never wanted to leave the
real thin ends...no real wall thickness left.
Now the reason for the post....was helping in someones shop,
they have done lots of cage work and were working on the
main cage for a BIG pulling tractor. I cut some tubes for them
and was grinding the skinny pointed ends back when the mild
arguement starts. Basically they felt it's a total waste of time
and just weld them togather "as is". Didn't have any concerns
of the extremely thin wall areas around a good portion of the
tube....they thought I was nuts ( could be ...)
So with all that in mind, how does everybody else deal with
those real thin ends.
Dave P.
Results 1 to 10 of 23
Thread: Tube Notching
04-18-2008, 09:37 PM #1
- Nov 2007
- 184
Tube Notching
04-18-2008, 10:06 PM #2
I always grind off the thin edges after a notch is made. The "toe" and sides of a notch can get pretty thin at some angles.
04-19-2008, 09:50 AM #3
- Oct 2006
- 694
The problem with thin ends can be a problem if the welder just barely ties the weld into them. However, the welder can weld the joint such that it just melts the thin area into the weld, and the toe (edge) of the weld is up into the thicker area of pipe.
04-19-2008, 10:20 AM #4
- Nov 2007
- 184
Engloid,
I do that sometimes if it's just a little bit to deal with.
These were 2 in. tube with offset notches, would have had
to melt off at least 1/2in. to get anywhere near the full
wall thickness.
Dave
04-19-2008, 06:43 PM #5
I grind 'em back cause I want my welds as good as they can be. Depending on them to "melt" back may or may not be consistent. I am interested in controlling anything variable so I can get repeatable results.
I have been doing some sch 40 aluminum pipe projects lately and ran into that very thing. The welds were "ok" but the width of the bead would vary and the appearance suffered. The ones that I ground back with the beltsander/flapdisc had a much better looking weld. Also offset notch and VERY steep angle. 1" pipe on a 3 1/2" radius to 1 1/2" pipe on a 7 1/2" radius after running parallel.
On steel YMMV.Miller Dynasty 700...OH YEA BABY!!
Miller Bobcat 225 NT
Miller 30-A Spoolgun
Miller WC-115-A
Miller Spectrum 300
Miller Spoolmate 200
Miller 225 Thunderbolt
SPEEDGLAS 9100XX
04-19-2008, 06:51 PM #6
I grind back any "knife edges" until I have full wall thickness to weld to.
I figure that if the sanctioning body dictates a .095" wall thickness (for example) then THAT is what I should be welding together, and nothing thinner.Later,
Jason
Professional Spark Generator by Trade.
04-19-2008, 08:43 PM #7
04-19-2008, 10:01 PM #8
- Nov 2007
- 184
Thanks Guys....about what I thought, I'll see them again in
about a week or so and find out if they were just being lazy
or a little stupid, maybe some of both.
Dave P.
04-20-2008, 12:16 PM #9
- Jun 2006
- Killingworth,Ct.
- 372
Fm
Your not nuts
,But im with Jason and Kevin,Think its called PRIDE,also Fusion,and Engloid, Keep up the GOOD work!!!!!!!!!!!
,Hope I didnt miss anyone!
04-24-2008, 08:41 PM #10
- Oct 2004
- 72
Yep, knock them back until there's some meat to weld to.
You're not alone!
