Results 1 to 8 of 8
    Sep 2006
    Ft. Lauderdale
    1
    Default Removable Rear X-Brace
    Im in the process of adding an X brace to my chassis. One half of the X over the motor the other half in the halo bar. With that I need to install a removable V brace in the chassis over the rear mounted motor. The other V in the halo will be fixed. I think youll get the idea with this picture.
    That said, Im looking for the best way to build the removable V over the motor. Ive been looking a Tubing Couplers like these which seem like they might just do the trick,,,, but though Id see if you guys have any better ideas.
    http://www.denunzioracing.com/mm5/me...Category_Code=
    Thoughts?????
    Many thanks!
    May 2009
    Texas
    7
    The first question I have to ask is this car for street or competition? If it is for competition then check with your sanctioning body. There are many ways to create a removable brace. One is to simply slide a larger tube over the smaller tube at each end, thru drill them and bolt them in place. Some others are shown in the SCCA's 2009 GCR. If you google 2009 GCR it will take you to the web page where you can download it. It is a PDF file so you will need Adobe Acrobat Reader.
    Jan 2009
    28
    Default Heim joint
    HEIM JOINT Google it they come in all different sizes
    Sep 2008
    Omaha, NE
    447
    OT, but what trans is that and what's it from? Kinda reminds me of one from a DeTamoso Pantera but looks a tad different and it's seemingly hooked to a chevy motor?
    Fill me in on the car, I'm no help on the cage specs without consultin the same sanctioning body regulations you would have to follow buti don't know your class.
    Hobart Handler 135
    Smith MB55A-510 O/A setup
    Lathe/Mill/Bandsaw
    Hypertherm Powermax 45
    Just about every other hand tool you can imagine
    Mar 2009
    Corona, CA
    213
    Looks a whole lot like a Factory 5 GTM...
    And thats an LS6 (aluminum C5 Corvette motor) with what looks like a Porsche trans axle.
    Either way, its gonna run like a scalded dog when its done.
    Not so sure that I would run those tubing couplers...but thats my personal preference...I'd say a heim joint would do everything you need it to. You'd also have a double shear on the bolt, which could be say...a 3/4" grade 8 if you wanted it to be.
    Like SCCATECH said though, if its ever gonna run competition, look in the rule book and see what you have to do.
    Hope that helped.
    Precision is only as important as the project...if you're building a rocket ship...1/64" would matter. If you're building a sledgehammer...an 1/8" probably wont.
    Sep 2003
    Rhode Island
    33
    Brian C.
    Turbobrian Fabrication LLc.
    Miller D165
    Miller 140
    Miller Digital Elite
    Jan 2009
    26
    I'm building a VW pan based car. The cage is welded to plates on the rocker sills and also bolts to the pan. This allows the body to be seperated from the pan. For my seat bars, I welded from the sill bar to the pan (same with the diagonals from the seat belt bar to the tunnel) and used a coupler like this
    These are not the exact ones I got, but gives you the idea. My are for 1.75", but turned down to have the "neck" for 1.625x.134 tubing. They work good.
    Feb 2009
    Island Falls Maine
    562
    what ever your doing I think it will look good.
