Results 1 to 7 of 7
    Default Milling Feed And Speeds
    I need help I need to know is there a standard for mill feed? please help I am a welder but trying to get into machining
    3,655
    Try here for some answers.
    http://web.mit.edu/2.670/www/Tutoria...scription.html
    There are also lots of yahoo groups on milling machines most of them are brand specfic but the info is the same...Bob
    grab yourself a copy of the machinery handbook. pricey but really handy for this.
    you can buy / use some really nice cutters but it all comes down to how rigid/powerful the machine you are using is.
    dont buy 60 dollar endmills for practice
    National City CA
    1,086
    there is no standard. All material require a different feed and speed rate.
    don't get the two confused.
    Cutting speed is how fast the tool is turning in relation to the work on a mill or how fast the work is turning in relation to the tool on a lathe
    Feed rate is how far you move the tool per revolution in thousandths of an inch.
    aluminum is 200 Surface feet per minute
    Steel = 90 SFPM
    Tool Steel i.e. 4130/4140 a2, d2, stainless steel = 50 SFPM
    basically you need to remember a 1" end mill in a mill or a 1" bar in a lathe spinning at 360 rpm is equal to 90 surface feet per minute give or take a bit for rounding off the math.
    Cut the speed in half if you run 2" or double the speed if you run 1/2"
    feed rate is something all together different but basically no more then .005" per rev on a lathe and .030" depth for the inexperienced
    or 6 inches per minute feed at .030" depth on a mill.
    Find a machinist and ask questions.
    Machine tools are very dangerous and I've seen parts thrown across the shop or 2" bar bent 90 degrees in the lathe
    BE CAREFUL!!!!
    South bend lathe 10LX40
    K.O. Lee surface grinder 6X18
    Auto shades are for rookies
    www.KLStottlemyer.com
    Vancouver BC Canada
    605
    Bob, Thanks alot, very informative for some basic info.
    Miller 251/30A spool
    Syncro200
    Spectrum 625
    O/A
    Precix 5x10 CNC Router12"Z
    Standard modern lathe
    horizontal 7x12 bandsaw
    Roland XC540 PRO III
    54" laminator
    little dog
    Jul 2007
    115
    Go over to the "practical Machinist " forum.
    John1
    National City CA
    1,086
    Someone mentioned the machinery handbook, It's good but also near $75 for a new copy. A better book that I had when I was in my Tech school was the Machinist's ready reference about $20 and has 90% of what a machinist needs to know one a daily basis. Feeds, speed, chip load, tap chart, trig tables, Like I said 90% of the day to day stuff is in there. But when I could finally afford a copy of the machinery hand book i got one. It's an indispensable book.
    Kerry
