Results 11 to 18 of 18
    2,908
    Or just say "ornamental plate or flange"
    Apr 2006
    San Diego
    375
    BaddOOSS,
    I see you've got quite the anvil collection. Nice. I'm not much of an anvil guy, but I am a certifiable tool junkie... which can be a good thing and a bad thing. Mostly a good thing. I think most here would agree.
    Apr 2006
    San Diego
    375
    Default hey bert
    oh, and how did you "plant" those feet in the resturaunt? I didn't see any lag bolts???
    Hi Bert,
    We laid out the uprights for the railing on the slab before the tile went in.
    If I remember correctly, the uprights on the railing were 3/8 x 2 flat bar.
    We probably had the holes cored to 3" diameter so we can just pour the railing in place. This is a clean way to do it, you just have to make sure nobody monkeys with it while it's setting, as you're provisions for levelling are literally "set in stone." The escutcheons- excuse me, ornamental cover plates- were also from 3/8" material, slotted to fit over the 3/8" x 2 balusters. So... no bolts.
    When you do thing this way, there's always that nagging feeling of "I sure hope I welded this thing together correctly to fit the cored hole pattern..."
    Usually it works out.... usually.
    Measure twice. Don't lose your measurements. I'm horrible and often find key measurements on the side of a cardboard box, napkin, back of my hand. Yikes.
    Thanks for the interest.
    Oahu, Hawaii
    2,469
    Quote Originally Posted by chris***@sbcglo View Post
    Hi Bert,
    Chris, ok...before the railing is set in "stone", do you put the escutcheons in, then set the railing in the hole? then you tile over, then the escutcheons are what...epoxied down onto the tile?
    Sorry for being a dummy about this. Never seen it done before..also, the scrollwork? custom made? or bought?
    thanks Chris!!!!!!!!!!
    I'm not late...
    I'm just on Hawaiian Time
    Apr 2006
    San Diego
    375
    Escutcheons are slipped on the railing before it is set. They can be glued down if you like. Tile went in before railing. They left our holes open for us.
    Scroll work was cut with a water jet to my design. We had lots of time on the machine and it was not cheap.
    The pattern on the fixture was cut in .050 aluminum. There were 4 sheets of 4' x 10'.
    The railing was cut from 3/8" mild steel.
    I out-source this cutting and when they hit me with the bill, it hit HARD.
    Oahu, Hawaii
    2,469
    THANKS CHRIS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    You didn't get that waterjet quote before you started/put the bid out?
    I'm not late...
    Apr 2006
    San Diego
    375
    THANKS CHRIS)!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    I was in the ballpark, but sometimes it still hurts even when you know it's coming.
    Oahu, Hawaii
    2,469
    Don't I know it!!! I'm like..."Oh look! I just made another charitable contribution!!!"
    I'm not late...
