    Feb 2008
    Milwaukee WI
    57
    Default rock slider project (metal question)
    As my next project I am making some Rock Sliders for my truck (95 Nissan Pathfinder (4000 lbs))
    Using 2" x .120 wall DOM steel tubing, for mounting plates I am unsure what to use & am thinking grade 50 steel plates
    (6" wide but what thickness would be recommended)
    I am going to bolt & weld plates onto the frame outside & bottom of frame rail at 4 points on each side.
    Not sure if I made sense yet as I am just getting caffinated after a long night with an Exchange server I hate Bill Gates some days
    Millermatic 210
    2,634
    Why Grade 50?
    These are rock sliders not bridges
    Seems like Mild Steel would work just fine.
    Mpls, MN
    1,762
    Mild steel would work perfectly. No need for anything over 1/4". Chevy full size truck frames are made from 3/16".
    A few well placed gussets and you'll be ready to slide.
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Thermal Dynamics Cutmaster 81
    Smith O/A rig
    Cave Creek Az
    796
    And why the heck would you want to use DOM for rock sliders, have you priced it yet? Mild steel will work perfectly for those.
    Midland, Mi.
    313
    I hate to say it but, a lot of wheelers use pipe for sliders. Pipe doesn't seem to dent as easy as DOM or mild steel tube.
    Feb 2008
    Milwaukee WI
    57
    I was going off of specs from other sliders with the DOM and at some point I would like to make a winch bumper. (I am in welding terms; a PC guy & welding is just a hobby which I enjoy greatly) wish I would have done more when I was younger!
    sliders seemed a safe enough test as if they fail I will just dent my truck. mild steel it is!-)
    thanks for the direction, still learning my grades of steel
    Millermatic 210
