Results 21 to 30 of 34
06-07-2007, 03:06 AM #21
06-07-2007, 04:26 AM #22
cool that would be verry helpfull.
like i said i think O/A and most likely brazing is going to be the best fit.thanks for the help
james@newyorkmetalart.com
06-07-2007, 02:41 PM #23
- Jun 2007
- 4
Looks like I will for sure start out with OA and deoxidized copper welding rod. I will keep one eye open for a TIG while I'm at it (depending on my results).
From my research, the copper sheet metal shouldnt be a problem with OA. What about plumbing pipes? Just looking at the 1/2" & 3/4" rigid copper pipe at Home Depot.
Are there any good sources of info online for welding copper with OA?
Once again, I want to thank everyone for their input! Lots of good info.- 250 Bobcat
- too many irons in the fire
06-07-2007, 02:53 PM #24
SZ,
The plumbing type pipe welds just fine, in fact we buy ours from home depot for engineering projects. Kent White has some copper info at his site in the technical area, He has a good booklet on the subject as well. Otherwise the guys at www.metalmeet.com in the forums talk of welding copper as well.
Good Luck!
-Aaron"Better Metalworking Through Research"
Miller Dynasty 300DX
Miller Dynasty 200DX
Miller Spectrum 375 extreme
Miller Millermatic Passport
Miller Spot Welder
Motor-Guard stud welder
07-14-2007, 08:16 AM #25
- Nov 2005
- 23
welding copper to copper
If it is decorative, Oxy-acetylene does the job...parent metal as filler....I do it all the time....practice makes perfect....weldress
09-12-2008, 07:13 PM #26
- Sep 2008
- 1
[QUOTE= only certian grades of copper are weldable, although most are able to be brazed, soldered etc.... You would be prety limited on the thikness. We push our sync. 350's at work nearly to the breaking point on the copper/nickle stuff we do.
How can you find out what grade is weldable? I never had any problems with a torch, why with a TIG?
Also I am interested in buying a Tig for welding copper on copper. What about the Dynasty 300 DX. I think the 200 DX just doesn't have enough amp power to puddle it. Unless you go to Helium/Argon mix??
Any imput would be great, thanks,
Kim
09-13-2008, 03:17 AM #27
I've done this
When I got my first TIG welder I did exactly what you are inquiring about. I was just experimenting, welding razorblades together and such. I thought I'd try welding 1/2" copper pipes. I melted the first one down, but then I got the hang of it. It needs to get very hot, nearly to the point of melting the copper, then you hit for a second and it welds. The puddle doesn't last long enough to really see it. The whole tube just oops out before that happens.
That welder was a $200 (on sale) Harbor Freight 130A scratch start inverter tig welder. It doesn't take a lot of heat to weld 1/2" type L copper pipe.
Yes, you need a lot of heat to weld copper sheet because every inch the heat travels, it gets an inch further away from the arc... but on small diameter pipe, when the heat travels an inch - well, it's almost right back where it started. Or in more thermodynamic terms, it cant utilize it's thermal mass as efficiently as a sheet because it can only move up and down the axis of the pipe instead of radiating outward in all directions on a sheet.
I found the best way to do it was to make an autogenous weld by melting the edge of the fittings over and onto the pipe. I held the torch with the right hand and used my left hand to rotate the amperage control like a "poor man's pulse".
The results were very aesthetically pleasing. The welds were virtually indistinguishable from the rest of the pipe. I showed my sister the completed fittings and she seemed to think they'd make excellent drug paraphernalia. I didn't set out to make a dope pipe, so I broke it and chucked it in the scrap pile, otherwise I'd show you pictures.
09-16-2008, 09:22 PM #28
Copper
Why not use silver solder and braze it? I use it all the time for copper to copper, copper to steel, and copper to brass. It's strong on withstands temperature changes. It won't be good for sheet metal. My friend works for a flashing manufacturer and they use plumbing solder or tig with copper or brass rod.
LanceLast edited by lanceman73; 09-16-2008 at 09:30 PM.
Millermatic 210
Syncrowave 200
Spectrum 625 X-treme
Hobart Champion 16 W/
Miller 8VS Suitcase
Miller 3035 Spool Gun
Tons of Tools
Microwave
Laptop and Printer
Speakers in the Back for all to hear Sirius Radio!
10-29-2008, 11:42 PM #29
- Mar 2006
- 8
copper TIG
When I was in the automotive industry, I welded over a million welds. Mostly aluminum. I tried experimenting with lots of stuff.
Copper water pipe welds fine with a 350 miller, only had AC, as the place I worked didn't want to spend the extra $ for DC machines......I used #14 electrical wire, and it welded just like aluminum. Never needed over 200 amps.
I also repaired a copper sink with a different machine, same wire, but with DC, and it sucked. I got it done, but it was much more difficult. I was tempted to switch to AC, but was told by someone who was supposed to know, that DC was best, and I didn't want to make it look different as it was about a $5,000 sink.Check out survivalblog.com, and Fredsm14stocks.com
10-31-2008, 07:08 PM #30
- May 2008
- Troy, MI
- 277
I was able to TIG weld 1/16" copper with my Dynasty 200 DX. I agree that a larger machine would handle larger or thicker pieces. Here is a link to my original post:
http://www.millerwelds.com/resources...68&postcount=1
Miller Thunderbolt
Smith Oxyacetylene Torch
16" DuAll Saw
15" Drill Press
20 Ton Arbor Press
Bridgeport
so wile all the advice is good it dose not all fit his need.
