Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 34
  1. #21
    Dec 2006
    Alaska
    732
    Quote Originally Posted by fun4now View Post
    you have to keep in mind he is not doing structural weld but rather art work requireing only that it atach for decoration, not to hold a load. so wile all the advice is good it dose not all fit his need.
    I doubt that any power source hooked into a 1 phase 220 outlet would eaven get a puddle going on standard copper pipe say 1/2" id.
    Ill give it a try tomorrow on my dynasty 200 and let you know how I do.
    TJ______________________________________
  2. #22
    Aug 2006
    near rochester NY
    9,881
    cool that would be verry helpfull.
    like i said i think O/A and most likely brazing is going to be the best fit.
  3. #23
    Jun 2007
    4
    Quote Originally Posted by Anti-GMAW View Post
    Keep in mind that only certian grades of copper are weldable, although most are able to be brazed, soldered etc.... The econo tig and the 200 wont have the power for any real welding on copper. You would be prety limited on the thikness. We push our sync. 350's at work nearly to the breaking point on the copper/nickle stuff we do.
    Looks like I will for sure start out with OA and deoxidized copper welding rod. I will keep one eye open for a TIG while I'm at it (depending on my results).
    From my research, the copper sheet metal shouldnt be a problem with OA. What about plumbing pipes? Just looking at the 1/2" & 3/4" rigid copper pipe at Home Depot.
    Are there any good sources of info online for welding copper with OA?
    Once again, I want to thank everyone for their input! Lots of good info.
    - 250 Bobcat
    - too many irons in the fire
  4. #24
    Dec 2005
    wisconsin
    836
    Quote Originally Posted by subzero View Post
    SZ,
    The plumbing type pipe welds just fine, in fact we buy ours from home depot for engineering projects. Kent White has some copper info at his site in the technical area, He has a good booklet on the subject as well. Otherwise the guys at www.metalmeet.com in the forums talk of welding copper as well.
    Good Luck!
    -Aaron
    Miller Dynasty 300DX
    Miller Dynasty 200DX
    Miller Spectrum 375 extreme
    Miller Millermatic Passport
    Miller Spot Welder
    Motor-Guard stud welder
  5. #25
    Nov 2005
    23
    Default welding copper to copper
    If it is decorative, Oxy-acetylene does the job...parent metal as filler....I do it all the time....practice makes perfect....weldress
  6. #26
    Sep 2008
    1
    Smile
    [QUOTE= only certian grades of copper are weldable, although most are able to be brazed, soldered etc.... You would be prety limited on the thikness. We push our sync. 350's at work nearly to the breaking point on the copper/nickle stuff we do.
    How can you find out what grade is weldable? I never had any problems with a torch, why with a TIG?
    Also I am interested in buying a Tig for welding copper on copper. What about the Dynasty 300 DX. I think the 200 DX just doesn't have enough amp power to puddle it. Unless you go to Helium/Argon mix??
    Any imput would be great, thanks,
    Kim
  7. #27
    Feb 2008
    893
    Default I've done this
    When I got my first TIG welder I did exactly what you are inquiring about. I was just experimenting, welding razorblades together and such. I thought I'd try welding 1/2" copper pipes. I melted the first one down, but then I got the hang of it. It needs to get very hot, nearly to the point of melting the copper, then you hit for a second and it welds. The puddle doesn't last long enough to really see it. The whole tube just oops out before that happens.
    That welder was a $200 (on sale) Harbor Freight 130A scratch start inverter tig welder. It doesn't take a lot of heat to weld 1/2" type L copper pipe.
    Yes, you need a lot of heat to weld copper sheet because every inch the heat travels, it gets an inch further away from the arc... but on small diameter pipe, when the heat travels an inch - well, it's almost right back where it started. Or in more thermodynamic terms, it cant utilize it's thermal mass as efficiently as a sheet because it can only move up and down the axis of the pipe instead of radiating outward in all directions on a sheet.
    I found the best way to do it was to make an autogenous weld by melting the edge of the fittings over and onto the pipe. I held the torch with the right hand and used my left hand to rotate the amperage control like a "poor man's pulse".
    The results were very aesthetically pleasing. The welds were virtually indistinguishable from the rest of the pipe. I showed my sister the completed fittings and she seemed to think they'd make excellent drug paraphernalia. I didn't set out to make a dope pipe, so I broke it and chucked it in the scrap pile, otherwise I'd show you pictures.
  8. #28
    May 2008
    San Diego
    180
    Default Copper
    Why not use silver solder and braze it? I use it all the time for copper to copper, copper to steel, and copper to brass. It's strong on withstands temperature changes. It won't be good for sheet metal. My friend works for a flashing manufacturer and they use plumbing solder or tig with copper or brass rod.
    Lance
    Millermatic 210
    Syncrowave 200
    Spectrum 625 X-treme
    Hobart Champion 16 W/
    Miller 8VS Suitcase
    Miller 3035 Spool Gun
    Tons of Tools
    Microwave
    Laptop and Printer
    Speakers in the Back for all to hear Sirius Radio!
  9. #29
    Mar 2006
    10
    Default copper TIG
    When I was in the automotive industry, I welded over a million welds. Mostly aluminum. I tried experimenting with lots of stuff.
    Copper water pipe welds fine with a 350 miller, only had AC, as the place I worked didn't want to spend the extra $ for DC machines......I used #14 electrical wire, and it welded just like aluminum. Never needed over 200 amps.
    I also repaired a copper sink with a different machine, same wire, but with DC, and it sucked. I got it done, but it was much more difficult. I was tempted to switch to AC, but was told by someone who was supposed to know, that DC was best, and I didn't want to make it look different as it was about a $5,000 sink.
    Check out survivalblog.com, and Fredsm14stocks.com
  10. #30
    May 2008
    Troy, MI
    371
    I was able to TIG weld 1/16" copper with my Dynasty 200 DX. I agree that a larger machine would handle larger or thicker pieces. Here is a link to my original post:
    http://www.millerwelds.com/resources...68&postcount=1
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Lincoln SP-250 MIG Welder
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Miller Spectrum 375 Plasma Torch
