Page 6 of 6 FirstFirst 123456
Results 51 to 52 of 52
  1. #51
    Evansville, IN
    2,348
    Turboglenn the marks should cause no major effecgt except when you grind further up the tungsten later. I the marks are really deep it could cause an issue with tightening the collet onto the tungsten but otherwise NO PROBLEM.
    Peace,
    Paul
  2. #52
    Feb 2006
    3,711
    I sharpened tungsten for many years on a dedicated grinder, but finally switched to a unit made by Diamond Ground Products. Great stuff. Check them out: http://www.diamondground.com/
    I use the Piranaha III, LRamberson uses the P II, and KB Fabrications uses the P III as well.
