Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 52
  1. #31
    Indiana
    541
    SLOW in the cordless drill, dull part of the belt on the belt sander. Dull area because the sharp areas will break off the point.
    Tim Beeker,
    T-N-J Industries
    (my side bussiness)
    Esab 450i with wire feeder
    HH135 mig
    Miller aircrafter 330 - sold
    Marathon 315mm coldsaw
    table saw
    Dewalt cut off saw
    Sand blast cabinet
    lots of hand grinders
    Harris torch
    beer fridge
  2. #32
    Apr 2008
    Carlsbad, CA
    27
    I have always used a 6" bench grinder with a carborundum wheel for sharpening. (no tool rest) It was about 20 feet from the welding table. The trips back and forth to the grinder got old pretty fast, forcing me to be a better welder. I still dip the tungston fairly often, especially when welding "out of position", so purchased a Sharpie from Arczone. I like having it handy to grab without having to get up. It produces consistant points, and the diamond wheel reportedly doesn't collect metal, so you can grind for alumimum or steel welding with no cross contamination. It is not a must have tool, but saves a lot of steps over time. Battery operated would be even more convenient. (no cord to burn or clutter up the table)
    Russ
    BFM
    Passport Plus
  3. #33
    Dec 2005
    San Diego, CA
    168
    Default Belt sander works for me
    Guys - I'm a hobby welder, I've been sharpening my 2% thoriated tungsten on a 4 x 50 belt sander made for edge sanding wood. I hold the tungsten with a 1/2" Ericson drill extension w/ 3/32 collect.
    I work in an aerospace shop where we weld aluminum, titanium, various nickel alloys. The welders in the shop use a 1 x 42 belt for tungsten used in hand welding and a mechanical sharpener for the bigger tungsten used on the machines.
    The belts on both are aluminum oxide. The weld engineers don't seem to worry about the grit type. Each weld is x-rayed.
    Are we doing something wrong? Should I never fly again?
    Frank
    (aka Fred)
    MM200 (antique and still cook'n)
    Lincoln 160 buzzzzzz box - left to live with a nice youngster
    Dynasty 300DX
    Spectrum 625
    Chevalier Knee Mill - Bridgeport clone you idiot.
    Homebuilt tube bender - with home made dies no less
    Delta Drill Press & Grinder collection
    Needed - a bigger shop to use the stuff
  4. #34
    Sep 2006
    Washington State
    73
    Default sharping
    I bought a sharpening tool to get mine sharp..I went to Arczone.com its not cheap.. but when Im out inthe field dragging a bench grinder around just wasnt handy. its about 200 bucks for it but makes sharping simple
    trailblazer 280 nt with 3000 hrs and running strong
    today I bought a new trailblazer 302
    and a new s-32p
    dynasty 200 dx
    maxstar 140
    passport
    XR pushpull
    spectum 500
    cutmaster 50
  5. #35
    alabama
    751
    Quote Originally Posted by Steve View Post
    Just below the carbide grinder is another grinder with a 6 in x 3/4 stone on it that has off center a groove from twirling tungsten. I just use at least the diameter to diameter and a half the size. I have broken the tip off, used a belt sander, the front side of side grinders, Hmmm, never rubbed on a point on the concrete yet nor tried chem sharp. What other methods have we all used and still got good results to our surprise?
    CUTTING TORCH
    2- XMT's 350 cc/cv
    1- BOBCAT 250
    1- TRAILBLAZER 302
    1- MILLER DVI
    1- PASSPORT PLUS
    1- DYNASTY 200 DX
    1- MAXSTAR 150 STL
    1- HF-251 BOX
    1- S-74d
    1- S-75DXA
    2- 12-RC SUITCASES
    1- 8-VS SUITCASE
    2- 30 A SPOOLGUNS
  6. #36
    Queens NY
    1,547
    Its funny how much of a personal preferance this is. I started with a belt sander, but i guess as a shaky noob it quickly became a nuisance to set it up (hand held unit) and it was kinda slow. I use a diamond flatlap now and love it. In a TIG class we were using a bench grinder. I found it slow and dangerous especially as the tungsten got shorter. I also found that i couldn't get as pointy of a tip or a clean square flat (inverter alluminum). I used grinder sharpened vs diamond and i seem to weld better with the diamond. Maybe its because i use lanthanated, since it requires a point for both steel and alluminum i have to sharpen twice as often. I also think its harder than thoriated so may be thats why it feels slow to me. I didn't have a drill in class so sharpening the shorties was also scary. I think if your happy with what your doing it's not worth the effort to change, but i think if you tried a diamond wheel of somekind you would not want to go back
    Dynasty 200 DX
    Millermatic 175
    Spectrum 375
    All kinds of Smith OA gear
  7. #37
    Nov 2007
    Southern Louisiana
    421
    Default is there a right way
    Ant1277,
    yes there is a right way, the one that keeps you safe. You can see from this thread that there are alot of ways to get the same job done.
    In the end for a good quality arc from your tungsten there are a couple of things to remember.
    the first thing is that the electrode will carry the current until it tapers enough that it's is over its capacity, that is when the current will leave the electrode. We like to call it an arc, sometimes if we aren't careful it is a shock, been there myself. Since the current is going to leave the electrode at some point we try to control it by grinding the tip. As we reduce the cross sectional area of the electrode we are determining where the current will leave. Try this experiment, sharpen the tip to 1 1/2 the diameter of the electrode. The grind on a 1/8" diameter would be 3/16" long for example. Make sure the grind is even (the same length) all the way around the tungsten, keep the finish smooth so the cross section is consistent. Leave the tip pointed. Now start welding will a very low current, if there is enough to start an arc it will be coming from the bottom of the electrode right next to the tip. It will come off of the electrode evenly aroung the cross section. Now raise the amperage and notice that the arc is coming off the electrode higher up than before. You can keep it going until you over power the electrode and need a larger diameter.
    When you finish that test, grind it again to 1/2 the diameter of the electrode. So for the 1/8" it would be 1/16" taper and try the test again. You will see that the arc is very controllable by just how we grind the tungsten. By changing the taper we can change the width of the arc.
    Now is blunting the electrode important? yes AND no. By running these tests you will find the part of the electrode you won't use, your amperage won't go that low. So instead of having it hanging down there waiting to dip in the puddle, just grind it off. Again evenly and smooth.
    Following the manufacturers recomendations of current capacity and preparing the electrode with an understanding of why it is critical will help you make better welds. It has worked for me.
  8. #38
    Jan 2008
    Colorado
    673
    Lightbulb
    And the light goes ON.
    I finally understand 'truncating' the tip. Dip clearance.
    Diamondback, Thanks.
    Craig
    RETIRED desk jockey.
    Miller Syncrowave 250.
  9. #39
    Quote Originally Posted by Fred Smith View Post
    A dedicated tungsten grinder will offer a consistent taper, for example, which will eliminate at least one variable in an automated welding application... Also some of the machines also offer dust collection which may be a concern in some shops. For some folks, a machine like the Sharpie (which is our most popular, btw) is just a terrific tool for convenience-- its not that you can't prep your tungsten with other methods.
    That said, I always say, if it works don't fix it... :-)
    Carmen Electrode (Arc-Zone.com)
    CarmenElectrode.com
    powered by... Arc-Zone.com (R) Inc.
  10. #40
    Feb 2006
    Paradise
    13
    Quote Originally Posted by RWC View Post
    Russ
    Sounds like my story. I too like the convenience of having the Sharpie right at the jobsite.
    BTW, I've gotten terrific support from Arc-Zone on replacement parts too.
    Randy Forbes
    Sports Cars Plus, LLC
    BMW M Coupe/Rdstr S p e c i a l i s t (weird censorship)
    Toledo, Ohio
    Spectrum 625
    Millermatic 175
    www.spcarsplus.com/gallery
