Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 52
  1. #21
    Oahu, Hawaii
    2,469
    Quote Originally Posted by Engloid View Post
    They use a really wicked powdercoating on tank trucks, tanks, and stuff like that. The MSDS was like reading an encyclopedia.
    Thanks!!!!!!! My point exactly!!!!!
    I'm not late...
    I'm just on Hawaiian Time
  2. #22
    May 2008
    I am new to TIG and got this tip from an old timer using Chem Sharp.
    Extend the tungsten about an inch out of the torch
    Start an arc to heat up the tip
    Dip in Chem Sharp a few times and you get a nice sharp point
    Slide the tungsten back in to the correct stick out and your on your way.
    This can be done right where you are welding without having to take the tungsten out and walk over to the grinder.
    Chem Share under $20
    Tungsten grinder over $500
    Syncrowave 200
    Millermatic 210 3035 Spool gun
    Millermatic Passport
    Blue Star 185
    Thermal Dynamics Cutmaster 38
  3. #23
    Chem sharp works fine. It takes a bit of getting used to in order to get consistant points. You can easily get too much of a taper or even have part of the tungsten get thinner and thicker before the point. Dipping and letting the Chem sharp roll on the tip and dipping again and again just enough to keep the reaction going. When done, brush off with your dedicated SS brush and weld on. There will be hard crust deposits that form in the chem sharp. You can crush these up or just pull them out and toss them. Try not to breath the fumes generated by the sharpening reaction.
    Have fun!
    A
  4. #24
    Alberta Red Deer
    373
    that stuff works great, but tricky to use at first but no contamination, which is great.
    trail blazer 302
    hypertherm plasma
    millermatic 251
    high feq. arc starter
    suit case (extreme 12vs)
    o/a torches
  5. #25
    May 2008
    Camillus, NY
    59
    Am I the only one who runs the tungsten, on the grinding wheel, in a cordless drill to get a real quick and very well shaped point?
    Jack
  6. #26
    East Tennessee
    141
    Quote Originally Posted by platypus20 View Post
    Jack
    No you're not... That's one place where a cheap underpowered drill does a good job!
  7. #27
    Alberta Red Deer
    373
    i use the a old drill and bench grinder too but i also have a jar of chem sharp too, but it takes a little longer.
    trail blazer 302
    hypertherm plasma
    millermatic 251
    o/a torches
  8. #28
    Lake of the Ozarks MO
    3,559
    Jack
    Not hardly
    I also use cordless and 21" belt sander as well and love the results that it gives too
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    SPEEDGLAS 9100XX
  9. #29
    Noth Dakota
    505
    Just below the carbide grinder is another grinder with a 6 in x 3/4 stone on it that has off center a groove from twirling tungsten. I just use at least the diameter to diameter and a half the size. I have broken the tip off, used a belt sander, the front side of side grinders, Hmmm, never rubbed on a point on the concrete yet nor tried chem sharp. What other methods have we all used and still got good results to our surprise?
  10. #30
    i use a little 1" diamond wheel from HF in a dremmel tool to sharpen my Tung. cuts fast and clean. i suspect its the same or smilier to the sharpie, without the head to line up the tung..mine is probly not a perfect point but close enough. also cuts the tung in no time. i generally point about 10 tung at a time and blunt the tip if I'm doing aluminum. take about 20 sec. to do a tip, less if i don't blunt the tip.
    HF has the 1" wheels in a 5 pack with holder for dremel tool for like $10 i think it was. its listed as a cut off tool i think.
    i'm planing to make a mount to hold the dremmel with a rest for the tung. should make sharpening even faster.
