Results 11 to 15 of 15
    Sep 2002
    pennsylvania
    102
    Make sure your output control is set to 100%
    19
    Just getting back to the thread. I will be checking these issues tomorrow and give you guys feed back. Thanks a Million for the help so far. I will be back!!!!!!
    DFW area
    180
    T. P.-
    If you've got a big project going, and have to suffer through it with a
    EconoTig--- once you get the pedal fixed:
    You (still) may, or may not have a large enough heat source for what you're doing.
    Hey,,,
    That's why some welders cost $1,500 bucks- and others cost $4,000.
    They're different, you aren't 'just buying the name' or a 'decal'-
    they really do different things, and the expensive one (really) is 'better'.
    But;
    You may be able to beat the system, or 'cheat'- for lack of a better word.
    A little known 'Guru' trick to help ya compensate for a small welder-
    and a big project, is to pre-heat the material around your intended weld,
    with a propane, a Plumber's "B" tank, or a 'soft' flame from a Oxy/acetelane- torch.
    If you're glueing together 1/4" Al. ,,, remember;
    Heat is your friend...........
    "Gone are the days of wooden ships, and Iron men.
    I doubt we'll see either of their likes again".
    Circa 1920.
    Author:
    Unknown US Coast Guard unit Commander.
    Near Dallas, TX
    214
    I've had trouble doing 1/4" aluminum with the econotig. You're probably going to need a good preheat. Also get ready for the overheat protection to come one when you least expect it. IIRC, The econotig is 20% duty cycle at full output.
    Some of the numbnuts mistakes I've made:
    Be sure the big "ker-chunk" switch is set to the LARGER of the two AC amp ranges.
    Be sure the knob is set to 100%
    May 2008
    San Diego
    180
    Pre heat is the key on all aluminum welding. Not only does it burn off inpurities, but starts you off hot.
    Millermatic 210
    Syncrowave 200
    Spectrum 625 X-treme
    Hobart Champion 16 W/
    Miller 8VS Suitcase
    Miller 3035 Spool Gun
    Tons of Tools
    Microwave
    Laptop and Printer
    Speakers in the Back for all to hear Sirius Radio!
