Results 1 to 7 of 7
    598
    Default making a trans cross member ?
    hello all.
    i have a 97 s10. i am putting long tube headers on it. the stock trans cross member will not correctly handle the drivers side pipe. so i am going to make a new cross member. i have some 1"ish .125" ish (i have the messure it) square pipe. i want the cross memeber to go over the exhaust. so a straight piece will not do it. i'm going to be over the pipe and under the trans, a good amount of fab'n going on. my question, do you think this pipe will handle it, and any tips ? thanx
    pics later
    we used 1/4 box tubing 2x2 on a 10 second big block car and it holds up
    miller 330 abp
    everlast 225lx
    airco 250a tig
    hobart handler 125 mig
    o/a torches
    Feb 2005
    N.E. SD
    1,381
    I used 2x2x3/16 square tubing on a '57 chevy pickup with a 327/4spd
    Easy and cheap, and it looks nice too!
    Jeff
    132
    Summit sells a generic trans crossmember and it's a fairly small pc of tube, so you probably don't need much.
    -James
    i personally wouldnt use anything smaller than 2x2 3/16, ive made three different tranny xmembers for toyota trucks to get rid of the big xmember that hangs below the frame, havent had a problem with it.
    Jan 2010
    guys, i have been checking threads about making a trans crossmember for my toyota truck. i wanted to know how did it go?
    Nov 2009
    sarasota,florida
    23
    I have used 1 1/4" .120 wall round tubing before, no problems 11.90 3400# El Camino . Darrell
