Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 59
    Nov 2007
    184
    I don't know what your taps equal in voltage but would
    suggest the the wire speed numbers you posted will be way
    out of the starting ballpark. I'd be thinking something
    more into the 200ipm range to start with.
    Edit
    You want to make up some practice joints. Don't just do em flat
    on a table, do them overhead, sideways, stand on one foot using
    your left hand with one eye closed etc. Do em while your upside
    down with sharp objects poking you in the ribs and back with
    sparks falling down your neck and you can't really see the weld area.
    These are real cage welding practice problems.
    Dave P.
    Austin, TX
    621
    Quote Originally Posted by FM117 View Post
    Dave P.
    Is there a practical welding test like this?
    Miller Maxstar 200 DX
    RMLS-14 Momentary Hand Control
    Miller Syncrowave 180 SD
    Porter Cable 14" dry metal saw
    Hitachi 4.5" grinder
    http://mhayesdesign.com
    Jan 2008
    VA
    298
    Edit
    Dave P.
    Add slithering in and out of the caged car about 20 times an hour too. Get in get placed and find that (fill in the blank) is not on/open/set right/pluged in/long enough or near you. Get out, correct issue, get in get set then get back out to welding hat that is sitting on top of the welder. Get back in and get right back out to answer the phone that is on the work bench and not in your pocket.
    Weekend wannab racer with some welders.
  4. #14
    Nov 2007
    184
    Vicegrip,
    You got the idea, add about 95 degrees and plenty of
    humidity, somebody that wants it yesterday
    (and was dumb enough to tell you they bent/broke
    it 6 weeks ago at their last event).
    Dave P
  5. #15
    Dec 2006
    612
    I would suggest building a rotisserie. "Not just for hog roasts anymore"
  6. #16
    Mar 2006
    La Porte, Tx.
    56
    Quote Originally Posted by tasslehawf View Post
    Yes, there is, for process piping.
    pull-do
  7. #17
    Jan 2008
    Colorado
    673
    Exclamation
    Edit
    Dave P.
    BINGO! This is exactly why I don't consider myself a real weldor.
    RETIRED desk jockey.
    Miller Syncrowave 250.
  8. #18
    Quote Originally Posted by Vicegrip View Post
    The actual welding is about 5% of the time spent building a good cage IMO. Thinking, planning, drawing, cutting, bending, fitting, cutting, fitting, recutting, fitting and tweeking are about 90%.
    This cannot be stressed enough. Think at least 3 steps ahead of yourself... it'll keep you from welding yourself into a corner... or more importantly a joint that you cant get the backside welded
    Scott Rhea
    It's not what you build...
    it's how you build it
    Izzy's Custom Cages
  9. #19
    May 2007
    Lebanon, Oregon
    31
    I just read this thread and will agree with everything in the replies, but I believe that there's been one important thing that was overlooked and it will show up during tech inspection.
    Creg stated that he wanted to use .095" x 1.5" tube for the roll cage. I would recommend that he get a rule book from whatever scantioning body this car will fall under and find out what the min. wall thickness allowed is. My point is, lets say, ......... the rule book says that the min. wall is .095", this will be where the problem lies. In the process of bending tubing, the tube will stretch and this will cause the wall thickness to become less than what it is when straight. If the rule book says .095" is the min. thickness allowed, then at most all the bends, in the roll cage, the wall thickness is less than .095" and the car can fail inspection. This is especially true when there are any 90 degree bends involved.
    Having worked with pipe and tubing most of my life and also the building of a few roll cages, this minor point has been overlooked quite a few times by others, until you hit the tech inspections, and that's where you DON"T want to find any BIG problems.
    You might want to check with someone in tech or somebody that does know if this will present a problem. I do know that when you bend pipe or tube something HAS to give and it's the wall thickness that does the giving.
    Just thought I'd bring this up, because I'd hate to see all your work go to waste for something that was overlooked, during your time consuming build.
    Hope this info helps.
    Bill
  10. #20
    Dec 2006
    612
    Good point Bill. When I saw it wasn't an NHRA or IHRA cage I didn't mention anything because I'm not familiar with anything but those 2 sanctioning bodies. I know my mild steel cage is .118" minimum by the rule book. The tubing I purchased from Art Morrison was .134'. I bought some from a speed shop @ .124". Even the .124" you have to mic & be very careful with.
