Results 1 to 8 of 8
    Mar 2007
    6
    Default drier for air compressor
    who makes a good drier for my air compressor? I have a Motorgard filter on the plasma but need something on the compressor itself that has a dissecant in it.
    thanks
    Feb 2007
    Central illinois
    98
    Default littleboss
    porter cable makes a good drier / lubricator or just a drier the same with cambell/hossfield
    miller bobcat 250
    wc 115a
    spoolmatic 30a
    centery 250 mic
    2 lincoln 225 stick
    a 1954 hobart portable welder w/ willies jeep engine
    Jan 2007
    Midland, Mi.
    313
    Apr 2007
    Machias, Maine
    4
    If you have a truck junkyard in your area you can put a truck air dryer on it . They are made for lots of air volume and have dessicent cartriges in them.
    Mar 2007
    6
    Thanks.
    I found a Campbell Hasfield at Amazon.com
    Mar 2007
    Fraser Valley, BC
    593
    Default Water fights
    Boy do we need an air drier at work. If the compressor has been running for a few minutes and no a lot of air is being used you can take an air blower and shoot a stream of water clear across the shop! We even showed our foreman the other day.
    Makita 5" grinder
    Makita 14" abrasive saw
    IR SS5L compressor
    and a wish list a mile long
    Aug 2006
    Oklahoma City, Oklahoma
    304
    just a thought, i run a basic velocity change drier with a filter element for general use and then have a refrigerant based drier for the more critical processes that I turn on when needed. I couldn't complain, gave $20 for the drier at an auction and all it needed was a new power cord.
    SSS
    Mar 2007
    511
    Talking
    Quote Originally Posted by shorerider16 View Post
    thats a sign to drain the tank.
    welding...its awsome
