Results 1 to 3 of 3
    Feb 2008
    9
    Default outlaw streetstock
    i spent this past weekend in the shop while it was snowing and snowing and.... well you get the piont.
    mid 80's cutlass(metric frame) transforming into an outlaw streetstock. i may end up finishing it and running the series here in the northwest or maybe not.
    hope you all enjoy.
    steve
    http://s31.photobucket.com/albums/c372/nwmod39/outlaw/
    Feb 2008
    9
    made small progress this week. did some more torch gutting of the body as well as notch the stock frame rails for the main cage hoop to tie into bottom frame rail.
    also did my first bends on the pro tools 105 manual bender.
    hmmm. now all i nee is real power run out to the garage and maye i could start getting more serious about the cage work.
    steve
    Austin, TX
    621
    Quote Originally Posted by nwmod39 View Post
    Heh. In the same boat.
    Miller Maxstar 200 DX
    Miller Syncrowave 180 SD
    Hitachi 4.5" grinder
    http://mhayesdesign.com
