Results 1 to 10 of 16
    Olive Branch Ms
    129
    Default Spoolgun frustrations
    I think I finally figured out my problems with my spoolguns. My heat was too high. All along I was thinking I gad gas coverage issues. The MM 210 gives a setting of 6/70 for 1/4", I turned it down and things got much better. I found a setting of 5/60 worked real well. Heres a few before/after pics. Adam
    Webb's Welding and Repair LLC
    MM210 w/a 3035 spoolgun
    Spectrum 625
    Trialbazer 302 w/HF
    http://webbsweldingandrepair.com/home
    Olive Branch Ms
    129
    I thought these got resized, apparently not. sorry for you guys w/dialup.
    Spectrum 625
    Trialbazer 302 w/HF
    3,899
    Nice work. Spoolguns are tricky at first. By the time you get them set right the jobs done unless its a big one...Bob
    Oahu, Hawaii
    2,469
    nice job! big difference!!!
    I'm not late...
    I'm just on Hawaiian Time
    Feb 2008
    Milwaukee WI
    57
    Wow;
    what a difference; very nice weld in the last pic
    Millermatic 210
    National City CA
    1,086
    Looks like my before and after shots. Before I learned to tig aluminum and after.
    I've never seen miged aluminum and have to say I'm impressed.
    South bend lathe 10LX40
    K.O. Lee surface grinder 6X18
    Auto shades are for rookies
    www.KLStottlemyer.com
    Olive Branch Ms
    129
    Thanks for the replies, I prefer to tig but the spoolgun is so much faster. I am going to start working on my vertical with it now that I have my welds looking decent. Adam
    Spectrum 625
    Trialbazer 302 w/HF
    MIRABEL , QUEBEC , CANADA
    50
    Thanks For The Advice And The Pictures , I Have The Same Set Up As You , But So Far The Spool Gun Is Still Brand New In The Box , Did Not Have A Chance To Use It , But It's Comming .
    Bobby
    FABRICATION-CRÉATION K ZEN
    MILLERMATIC 210
    SPOOLMATE 3035
    SYNCROWAVE 200
    HYPERTHERM 360
    Ukiah, Ca
    280
    I recently bought a 3035 for my mig machine,was very impressed with the ease of welding & weld quality. The recommendations inside the welder cover are very hot. I used to work at a job where I would use a Spoolmate II. It was very finicky, always burning back & ruining tips. I still use Tig for most of my Aluminum welding, but a friend just got me a side job of some forklift ramps; the spoolgun will get a workout.
    AutoArc 230 (MM 210)
    3035 spoolgun
    Spectrum 625
    Dialarc HF w/Coolmate 4
    i have a 210 with a spool gun and noticed that very same effect.. i did a alum. project a while back and had to crank it down .. even though usually the alum. needs more heat the steel.
    also dont forget you may had a little higher input of voltage then what the machine is calibrated for.. i know i get exactly 234 out of my outlet.. and im linked for 230 on my machine..
