Results 1 to 3 of 3
    Jun 2007
    Reno, Nevada
    31
    Default .030 flux core or .035 hard wire
    I purchased a dump truck last month. The truck has a pintle and my 12,000 lb trailer has a ball hitch. I am going to cut the hitch on my trailer off and install a pintle hook. The fabrication is going to be pretty straight forward. Will I get better penetration with .030 flux or .035 hard wire on my Passport Plus? Trailer tongue is 3/8. Thanks....
    8
    Default wire size
    .035 for sure. But on 3/8 you could run .030 hard wire as well. And remember if you have to weld vertical reduce you heat setting from what you would run a flat weld at 10-15% less for vertical up. Good luck.....
    Aug 2006
    Browns Valley, California
    1,713
    I'd run .030 hard wire. Much better arc density. Deposition rate ain't the issue here - it's penetration and fusion!
    Hank
    ...from the Gadget Garage
    Millermatic 210 w/3035, BWE
    Handler 210 w/DP3035
    TA185TSW
    Victor O/A "J" series, SuperRange
