I am going to be building a fence in the next couple of months for my grandmother. Her neighbor has one that she wants to duplicate, so I can get all of my measurements from that one, except for the custom gate for the driveway. The fence run will be 200' and for the front it will be about 100' with the gate.
Would it be best to build the fence in sections and take it out and set it, then weld it together? Or would you set the 4x4's and build it from there?
What type of paint would you use? The color needs to be black.
Any tools that would make the job a lot easier?
I will be using a millermatic 200.
Thanks in advance.
Results 1 to 10 of 21
03-27-2008, 06:17 PM #1
I need some tip on building a wrought iron fence.
They don't call me Lucky for nothin'.
03-27-2008, 06:32 PM #2
I would set the posts and make the sections to fit between them. Make a jig from a sheet of plywood or glue board to help in welding it up. I like the tractor enamel from the local farm store and some primer. I would paint the bottoms before installing them also...Bob
03-27-2008, 07:03 PM #3
I painted raw metal before with zrc cold galvanized, then put on some expensive oil based black. Almost a year, and with our salt air, it still looks like new...
I'm not late...
I'm just on Hawaiian Time
03-27-2008, 08:55 PM #4
Bert,
I have been wanting to find a spay type galvanize coating. How well does that stuff hold up? Is it durable by itself or does it need to be top coated?
Thanks alot.Tim Beeker,
T-N-J Industries
(my side bussiness)
Esab 450i with wire feeder
HH135 mig
Miller aircrafter 330 - sold
Marathon 315mm coldsaw
table saw
Dewalt cut off saw
Sand blast cabinet
lots of hand grinders
Harris torch
beer fridge
03-27-2008, 09:16 PM #5
- Feb 2008
- North of Phila. PA
- 404
The big problem with prefab is making sure the post are all the same distance apart. A little triming is ok but 2-3" diferent could be noticable depending on the style of fence. Either set the posts as you assemble the fence or make a jig to set the posts. I have a 4'X8' metal frame that I use to set posts for wooden fences. It has no wind resistance and keeps the next post in position while I plumb and brace it if pouring concrete or back filling.
The only other problem I see is if you have a lot of elevation change. You'll either have to be able to wrack the section or build in place. My metal frame is set up so I can wrack it if need be to account for a small hill, and wooden fences wrack no problem, iron fence, well depends on how its built.
03-27-2008, 10:32 PM #6
zrc paint
Sometimes I spray with the 14oz cans made by LPS that I get from the local hardware store (automotive section). I use LPS for spraying down electrical stuff, works good for me, so I figured I would try the cold galv. It has 95% zinc. If I have more time, I brush it on from a quart can from gaspro (also comes in gallon size). This stuff ain't cheap, but it works for me! The black topcoat is called "Anti Rust" made by Valspar "oil based enamel" That too is expensive, but I haven't found anything else that lasts as long...
hope this helps...I'm not late...
03-27-2008, 10:33 PM #7
Oh, btw...yes, you definately need a topcoat!!
I'm not late...
03-28-2008, 03:39 AM #8
Thank you Bert, good info.
Tim Beeker,
T-N-J Industries
(my side bussiness)
HH135 mig
table saw
Dewalt cut off saw
Sand blast cabinet
Harris torch
beer fridge
03-28-2008, 06:51 PM #9
Lucky, if at all possible make your sections at the shop and put it all together on site. Here is a little railing job that I'm working on right now. It is 28'4" long and has a 8'6" side extension. I built the 28' section in 3 pieces and put posts on both sides of the center section and made tabs for the end sections to bolt up together, same with the side piece. Maybe you can do something similar with your rails. As far as paint goes, I am sold on Rustoleum Rusty Metal Primer and then their enamel top coats. In this case it's semi-gloss black. Dave
03-28-2008, 10:05 PM #10
- Jun 2007
- arizona
- 105
fence
also check the price of powder coating vs the primer/paint. they do the sandblasting and coating and it will last a very long time. cat
