Results 1 to 10 of 20
    Mar 2008
    3
    Default need a machine for a max of 1/4" to 3/8" alum tig
    Hi guys,Thanks, I appreciate all of the knowledge on this board!
    I am looking to buy a inverter tig for some occasional welding. I will be using it for car customization and restoration. I have been trying to find my wildest project, and the most demanding thing I could come up with would be welding some 1/4" to 3/8" aluminum. It would be a tube to a open flange, so I could access both sides of the weld joint. I have been looking at all of the brands Miller Dynasty 200dx, lincoln 205, Thermal Arc 185 or ?, also HTP 201.
    Price is a huge factor for me, but I don't want to regret my purchase either.
    Will all of these machines be able to do this? Will I be working them to their limit?
    I was liking the HTP because I could get a whole liquid cooled set-up for less than air cooled Miller or Lincoln.
    Thanks again for your input.
    Browns Valley, California
    1,713
    Welcome aboard.
    If you plan on a steady diet of .375 aluminum, you'd better think 400-amp class machines. Aluminum needs lot of heat, as it heat sinks very effectively. My T/A 185 is rated at 3/16.
    Hank
    ...from the Gadget Garage
    Millermatic 210 w/3035, BWE
    Handler 210 w/DP3035
    TA185TSW
    Quote Originally Posted by hankj View Post
    Welcome aboard.
    Hank
    Yes, you will be needing quite a bit of current for 3/8" material...at least 350 to 400 amps.
    Apr 2007
    Ventura, California
    102
    Default Multiple pass OK?
    If you don't mind making several passes to build-up the bead on 3/8", then a Dynasty 200DX should be fine.
    However, as stated earlier, for single-pass beads you really need to crank-up the amps for thick aluminum.
    Dynasty 200 DX
    Coolmate 3
    with proper prep and pre heat you could get by with the 200amp welder, but it will get old fast. you would be better off looking at some thing in the 300 and up range. nothing against the Dyn 200 DX its a great welder as is the TA-185, but 3/8" is just not its thing.
    Feb 2008
    NEWPORT NEWS ,VA
    13
    What ya need is what I just got today check this
    2 TRAILBLAZER 302s AC/DC
    1 BIG40 DELUXE AC/DC
    2 MILLER HIGH FREQ. BOXES
    1 MILLER COOLMATE
    1 SPECTRUM 2050 PLASMA CUTTER
    1 SPOOLMATIC 30A
    1 MILLERMATIC 140
    1 LINCOLN LN-25 SUITCASE CC/CV
    INGERSOLL-RAND GAS POWERED AIR COMP.
    AND 2 BOX TRUCKS FULL OF TOOLS
    WWW.HOTWORXINC.COM
    National City CA
    1,086
    I have to agree
    My sycro wave can do alot of aluminum but it will only do so much and 1/4 to 3/8 requires preheat or a syncro 350.
    Aluminum is not cheep to weld at least from the machine cost point of view.
    kerry
    South bend lathe 10LX40
    K.O. Lee surface grinder 6X18
    Auto shades are for rookies
    www.KLStottlemyer.com
    Mar 2008
    3
    Quote Originally Posted by weldngod View Post
    Will they let me trade in my house and trucks on that thing??lol
    Actually, I don't think I'd be doing too many things with 3/8", that would be occasional. I probably do have a couple projects that I'd be doing with 1/4"
    Also, the 3/8" stuff is an open ended flange, so I will be welding the inside and the outside of it.
    Feb 2008
    NEWPORT NEWS ,VA
    13
    just warm it up with torch first.
    1 MILLER COOLMATE
    1 SPOOLMATIC 30A
    1 MILLERMATIC 140
    WWW.HOTWORXINC.COM
    Lake of the Ozarks MO
    3,446
    If you are looking at "list" price on Miller and Lincoln then you need to go back and price more.
    The contractor kit isn't all that good of a price so that makes miller seem high.
    Several internet sellers make better deals. I looked very hard at the HTP and was "sold" on it more than once but finally decided for an Italian machine it was not worth as much money as they wanted so I went with AMERICAN and am glad I did. I really cannot imagine using anything else now...it would be a step back except for maybe the Lincoln.
    As far as welding 3/8ths thick aluminum it depends on how big or the mass of the piece is. For instance a piece of say 3/8ths x 2" isn't a big deal at all to weld. I have welded well over 1/2" thick castings daily with mine. (skegs and other outdrive castings) 200 amps is actually a lot of power. If your flange is open and really only a half inch wider around the hole you have more than enuff juice to overheat the part.
    If you are trying to weld in the middle of a 4 ft square piece it would be tough but if you are talking about a flange like an intake it will handle it easily.
    I use a dynasty 200 DX daily for whatever anybody sends me. It paid for itself in less than a month. Only once did I opt to use my 400+ amp machine in the last few months that I've owned the Dynasty. I would put it up against anything in it's class.
    I also have been watching just how much amperage I do use and most of the time a 185 would do me fine. If your wildest project is 3/8ths then get it. If you end up needing more power you can sell a Dynasty or any of the machines you mentioned very fast on e-bay or Craiglist extremely easy.
    Miller Bobcat 225 NT
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Miller Spoolmate 200
    Miller 225 Thunderbolt
    SPEEDGLAS 9100XX
