Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
    Dec 2005
    wisconsin
    836
    Quote Originally Posted by Little View Post
    Thanks, guys. Great tips. I'm going to find some al flux. Do you guys suggest using 1100 rod? Or is 4043 good for this old 1948 car?
    Thanks again
    Little
    1100 all the way. 4043 ( and 4047) is actually an old alloy used for brazing believe it or not. Its high silicon content lowers the melting point below most wrought alloys, but it also makes the weld more brittle and unsatisfactory for sheet work. Your nose im guessing is either 2S or 3S as these were the most common at the time for body work, 1100 is the correct rod for it. Good Luck!
    -Aaron
    Miller Dynasty 300DX
    Miller Dynasty 200DX
    Miller Spectrum 375 extreme
    Miller Millermatic Passport
    Miller Spot Welder
    Motor-Guard stud welder
    Aug 2006
    near rochester NY
    9,881
    this might be of interest.
    http://www.harrisproductsgroup.com/c...lloys.asp?id=2
    although not the site i was looking for so i'll keep looking.
    Dec 2005
    wisconsin
    836
    Quote Originally Posted by fun4now View Post
    Yeah thats in the family of things to stay away from when doing sheet work or anything that moves. Brazing is normally used for putting in fuel filler necks and other bungs in tanks. 4047 is a great brazing alloy, as is 4043. Just use the old brazing formula flux and away you go.
    -Aaron
    Miller Spot Welder
  4. #14
    Mar 2008
    148
    HTS2000
    Looks pretty amazing!
    http://www.youtube.com/watch?v=fC9d1AroXR4
    RoyB
    Dartmouth, MA
    http://www.rvbprecision.com
    Millermatic 185 MIG
    Miller Diversion 165
    Purox W200 O/A
    Grizzly 9957 Mill
    Grizzly 4030 Metal Band Saw
    Grizzly 1050 Knife Belt Sander
    Jet 1236 Metal Lathe
    TP Blast Cabinet
  5. #15
    Dec 2005
    wisconsin
    836
    Quote Originally Posted by rbertalotto View Post
    HTS2000
    See my previous posts in this thread about that stuff. Either weld it, braze it, or solder it....but stay the heck away from that stuff if you care about the part your working on. The real materials are less expensive anyway.
    -Aaron
    Miller Spot Welder
  6. #16
    Nov 2006
    Lake of the Ozarks MO
    3,532
    Quote Originally Posted by Aerometalworker View Post
    -Aaron
    Now they are falling in love with that crap over at Hobart as well.
    Sheesh
    Anybody that did much repair learns to hate that junk pretty quick when you have to get it all out to fix it right.
    Miller Bobcat 225 NT
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Miller Spoolmate 200
    Miller 225 Thunderbolt
    SPEEDGLAS 9100XX
  7. #17
    Nov 2008
    Atl, Ga
    371
    Aaron/Aero-
    Are you using Kent's mystery flux or Allstate #? I'm proficient with TIG but I'd like to try my hand at gas welding AL. (A&P since '93)
    -Matt
  8. #18
    Dec 2005
    wisconsin
    836
    Quote Originally Posted by MR.57 View Post
    Aaron/Aero-
    -Matt
    Matt,
    I use both, The Allstate # is 35 for the welding flux. I too started with Tig, then graduated to the torch for real professional work on sheet.
    -Aaron
    Miller Spot Welder
