Results 1 to 3 of 3
    Raymore Missouri
    1,925
    Default All-State #31 aluminum rod
    I have a box( approx 5 lb) of All-State #31 aluminum rod I've had for 30 years. We used this with Alcoa #22 pink flux which is a powder to be mixed with water to form a paste to gas weld repairs on aluminum
    refrigeration coils etc. Does anyone know if this can be used with tig? It says on the box..Aluminum(GAS) on the box. It was difficult to weld because of the oil in a refrigeration system that would be present at the weld area. I would say my success rate was about 50%. Anyone familiar with this product?
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    Dec 2005
    wisconsin
    836
    Its 4047 alloy.
    Traditionally 4047 and 4043 were considered brazing alloys since they melt at slightly lower temperatures then most common wrought materials. When using these materials and the torch, you can literally "sweat" to parts together without melting the base material. This is common on things like fuel tank bungs, fittings, etc. where we use a lap joint and braze the fittings to the tank skin, it forms a nice fillet on both the inside and outside of the tank.
    Its pretty much impossible to braze aluminum with TIG so you kind of loose all the benefits.
    -Aaron
    Miller Dynasty 300DX
    Miller Dynasty 200DX
    Miller Spectrum 375 extreme
    Miller Millermatic Passport
    Miller Spot Welder
    Motor-Guard stud welder
    Raymore Missouri
    1,925
    I decided to try to tig with it. The first bead had a dull cast but two more beads came out very shiny, almost like chrome. Wierd!
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    2-O/A outfits
    Jet Lathe and Mill
    Propane Forge
