Results 1 to 10 of 15
    Olive Branch Ms
    129
    Default Backup gas for Stainless
    I was asked to repair a piece of stainless trim for a guys hotrod yesterday. It was really thin. Someone had tried to mig it and butchered it. I cut out the damage and put in a patch. It worked out good. I did not use any backup gas though and the underside of the piece did'nt look so good. I need to find some backup gas plates. They don't seem to be easy to find. I called Indiana Ox. no luck, No luck on e-bay. If anyone knows where to buy some let me know. I may just make some.
    Monte, I don't know if this will help your shiny/dull question but something I have started doing that seems to help is to make a quick lower current pass over the first couple of inches that I am going to weld. It seems to do two things. Preclean and preheat. Then back to the start and punch the pedal. The best welds that I get seem to be the ones where a good puddle forms quickly. Works for me anyways, Adam
    Webb's Welding and Repair LLC
    MM210 w/a 3035 spoolgun
    Spectrum 625
    Trialbazer 302 w/HF
    http://webbsweldingandrepair.com/home
    Deltaville, VA
    2,239
    Jet,
    What you're experiencing on the backside of the weld is called "sugaring". Very common when welding thinner SS.
    You're making too much of what constitutes a "backing plate". Basically all you need to do is create a "gas dam" for your purge gas (generally Ar). It can be fabricated from nearly anything. I have used sheet copper or aluminum flashing to create a gas pocket on the backside of the weld. Alum flashing works well, is cheap, and is easy to conform to the shape you need.
    You will need a second bottle of Ar and a separate regulator (or one of the dual output flowmeters).
    dose it have to be argon as a backer or could you get away with strait Co2 ? if your argon spair runs out and Co2 is all ya have on hand use it or wait till you get more argon ?
    Deltaville, VA
    2,239
    100% CO2 is the LAST thing you want around a SS weld.
    You want your purging gas to be an inert gas. CO2 is a "reactive" gas.
    Although CO2 is used in very small quantities in tri-mix (2 1/2%) it is definitely not recommended for a purging gas for SS.
    What about using a flux on the back side like Solar Flux instead of messing with the gas? Wouldn't that be much easier?
    Craig
    Lake of the Ozarks MO
    3,596
    On tig
    Forney mig wire even says co2 on 308L wire right on the box (100%) ...or at least they used to... so I tried it one day and it worked just fine. Not saying it's the best by any means but they said it and I did it.
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    i thought the pass port used Co2 for stainless, thats why i thought maybe it could be used as a back gas when TIGing.
    as for holding the back gas in place i have used tin foil taped to the back to make a chamber around the back of the weld. maybe not the best option, but it worked.
    Nov 2005
    107
    On little jobs I use this http://www.weldhugger.com/ but sometimes you have to make your own. They aren't cheap but pretty universal. Backshield with argon
    Deltaville, VA
    2,239
    Dang BVWELD,
    Neat little tool, but they are mighty proud of them.
    I can buy a lot of aluminum flashing and duct tape for those prices.
    Thanks for posting though.
    Nov 2005
    107
    Dang BVWELD,
    Don't forget the Reynolds Wrap You think thats high, price purge bladders
