Clavacle, That looks real good. I called my LWS to see if they carry the AR/HE mix. They do but he said its no good for thin aluminum. He's a salesman though and I don't know if he's just repeating what he's heard or if he really knows. Have you tried that mix on thinner material than 1/8? You guys are great to be willing to help people out. Adam
Results 11 to 20 of 21
Thread: Aluminum welds in question
03-18-2008, 02:39 PM #11
- Feb 2007
- Olive Branch Ms
- 129
Webb's Welding and Repair LLC
MM210 w/a 3035 spoolgun
Spectrum 625
Trialbazer 302 w/HF
http://webbsweldingandrepair.com/home
03-18-2008, 03:05 PM #12
From the hobby side of the tracks
I don't see the 'oxide cleaning zone' along the edges of your welds. And I think I'm seeing light 'peppering'. I just read in the Miller TIG Tips that means to turn the AC balance toward more cleaning.
My SW250 AC balance is 0-10 and is stenciled '3 for balanced and DC'.
0 is max clean, 10 is max penetration. I don't know how the 200 is marked.
FWIW: I'm a hobby weldor with a SW250. I think, at my level, tungsten type doesn't matter; it's an overblown issue. I use green or red because that what I was sold years ago. Sure the new stuff is better, but it doesn't matter to my brackets, widgets and gizmos. When I run out, I'll upgrade. Until you can run red long enough to get the little chrome b*lls on the tip, it doesn't matter; you'll be grinding your tung anyway.
But since the green forms a ball, it's not as good in a fillet as something that will hold a point. Red in my case, 2% lanthanated nowadays.
I hope I kept this in the context of a home hobby weldor. I do not want to contradict Sundown111, FusionKing and many others.
I'm welding in the home garage, not NASA.
Edited: And; weld that hole in your practice piece.
RETIRED desk jockey.
Miller Syncrowave 250.
03-18-2008, 03:14 PM #13
Craig.........who is your post directed to?
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
Miller Syncrowave 200 Tig
2-O/A outfits
Jet Lathe and Mill
Jet 7x12 horz/vert band saw
DeWalt Multi Cutter metal saw
Century 50 Amp Plasma Cutter
Propane Forge
60" X 60" router/plasma table
03-18-2008, 03:22 PM #14
Hi Nick:
The first two paragraphs, to you.
The rest of it was just aluminum 'thoughts', I guess.
Did I goof?
03-18-2008, 03:23 PM #15
- Dec 2007
- Oklahoma
- 641
Not bad. The red tungsten won't take up too much room in your scrap bucket. Do yourself a favor and put it there
Use lanthanated tungsten (1.5 or 2%)
Your technique looks to be ok- just keep on practicing
The porosity/contamination could be a breeze or fan in your shop blowing away your shielding gas
Remember that when practicing on one piece it will overheat and it is hard to wait on it to cool and the overheating will add to the frosted look.
You can tune your welds to the application or your desired appearance with your balance control. "7" is the normal for tig but do not be afraid to experiment
Also, add a little extra filler at the end of the weld. You do not want a crater at the end as the crater can lead to cracking
GriffLast edited by griff01; 03-18-2008 at 03:26 PM.
03-18-2008, 04:04 PM #16
- Aug 2007
- Seattle,WA
- 55
as far as the argon/helium mix on thinner aluminum: the thinnest aluminum we use is 1/8" so I can't really tell you how it performs on anything thinner. I do use it when making stainless steel electrical boxes. They are made from 16gauge 304 stainless. I just do fusion welds for all the outside corner welds with no problems at all. I havn't noticed much of a difference on the stainless work, but I would recomend the mix of gases for anyone doing aluminum, regardless of their skill level. With the helium in the mix the bottle empties slightly faster, but barley noticable, and I think there was about a $15 add in price but still well worth it.
Welders do it hotter!!
www.Munsonworks.com
03-18-2008, 04:05 PM #17
- Nov 2005
- 107
Like Craig said I would turn your bal. down to 3 or 4 and see if that helps. It looks like your fighting some contamination issues from the black flakes and surface oxides. Your scrap may have a heavier than normal oxide layer. When you clean with a S.S. brush you should feel a drag when you break through the surface oxides. Keep at it and good luck
03-18-2008, 04:35 PM #18
Tungsten for al.
Nick - I've used 2% thoriated for most all of my aluminum welding without any problems. I'm using a Lincoln Precision Tig 225 which I think is similar to your welder. One plus, however, is my machine has an auto balance setting which helps me. Based on amp and voltage settings, it automatically sets the balance. I don't think your welds are bad at all. Probably need to clean a bit better and speed up. Also, I also use 3/32" tungsten and filler for most all of my al. jobs.
As for Diamond Ground, I too had a problem getting samples using their online request form. I ended up having to call them. After doing so, I received some samples in just a few days.
I didn't notice any difference in the performance of the 2% lanthanated or tri mix compared to the thoriated. However, I will probably change to lanthanated when I reorder due to the radiation concern with thoriated. I'm not sure it's as bad as some think, but no need to take chances. After all, it's been in use for many years without documented ill effects when proper precautions are taken.
Good luck and keep practicing. It will only get better. BTW, mine aren't always great either.
03-18-2008, 05:29 PM #19
Actually fillets are pretty easy and could easily become your best looking welds. Your synchro 200 will make fillet welds with the best of them....trust me it's you not the machine. there are guys out there laying robot like welds with econo-tigs. You just have to put your time in thats all. If you are really serious go get a night job somewhere tigging aluminum and you will learn more in a week than you will at home in 5 years. I done it twice...just so I could raise the bar so to speak. And that's on top of having my own biz. Drove the old lady crazy...she MADE me quit my job. Didn't take me long to be the best guy there and you could do it too. Most of those guys would never put welding and the internet together.
Next time you do a fillet pull that tungsten out way further and you'll see some change in the focus of the arc also.Miller Dynasty 700...OH YEA BABY!!
Miller Bobcat 225 NT
Miller 30-A Spoolgun
Miller WC-115-A
Miller Spectrum 300
Miller Spoolmate 200
Miller 225 Thunderbolt
SPEEDGLAS 9100XX
03-18-2008, 06:48 PM #20
- Mar 2007
- Deltaville, VA
- 2,241
Clavacle,
Just had a couple comments/questions regarding your previous postings.
You originally stated that the bead displayed in your photo was done on 1/8" or 1/4" tube, couldn't remember which. That's the flattest tube I've ever seen. Must have a radius of about 8'.
If you or your company don't mind wasting money buying an Ar/He mix for the type of work mentioned (1/8" to 1/4") that's your business, but to tout it as a recommended mix for that type material is not good advice. There are definitely situations where the addition of He would be recommended, but this type of welding is NOT one of them. You don't need the heat and if you did, there's a little knob called Amps. There's a little marine tower builder called Pipewelders down in Ft. Lauderdale that goes thru about 80 large 100% Argon bottles a month. If there was a benefit, don't you think they'd be using a mix.
Also, when using a Ar/He mix, I've found it necessary to greatly increase my flow rate since the He is much lighter than air. 10 CFH (as you stated) seems mighty low to me.
Higher cost gas and more of it just doesn't make sense to me. Oh, and by the way, last time I checked a 75/25 fill cost a heck of a lot more than $15 more than 100% Ar. You priced any He lately?
Everyone seems to be looking for that "silver bullet" that will make them an excellent tig welder. Bottom line, there's no substitute for practice.
