Page 1 of 3 123 LastLast
Results 1 to 10 of 27
    Nov 2006
    Startford, Charlottetown, Prince Edward Island, Canada
    304
    Default Stainless project
    Hey guys, I'm starting my second project on stainless my first one was a pretty good success but I used 20g sheet metal and I don't have the ability to weld that yet one of the guys at DME had to go over it again in pulse to fix the damage I caused. Now I'm stating a stainless tool box which I will be doing myself with no help (other then the person who bent the sides I'm not allowed to use the press yet.) He also helped me with picking out the size etc. I'm going to be done of it hopefully early next week and at that point ill post pictures of both results. But could you explain to me how I can weld the 12g to 16g I realized id have to put most of the heat on the 12g (for the sides of the box) when I weld the joint I want to make sure I don't burn through it or warp it. I'm going to be trying welding a little and cooling it down with compressed air, I'm hoping that will solve my problem. any advice will be greatly appreciated I don't get to work on it again until monday which I'm really bummed on so I have the weekend to plan what I will be going through with doing. so thanks in advanced for the advice I will hopefully be getting.
    Mar 2007
    356
    if you want to minimize warping dont rely on compressed air, you will want to clamp it in every way possible
    as for the actuall welding, its not so bad, im shure you will figure it out
    mm210
    maxstar 150
    Mar 2007
    ****inson ND
    557
    Talking
    Compressed air will make oxidation occur more rapidly. It won't look as good and will lose some of it's ability to combat corossion.
    Jan 2007
    hillsboro,OR
    45
    weld a little at a time and weld all the sides evenly so do a little on one side and a little on the other .
    Millermatic 135
    Syncrowave 200 with coolmate 3
    Hypertherm powermax 30
    were I am when I am home
    http://i21.photobucket.com/albums/b2...5/IMG_7413.jpg
    Aug 2006
    near rochester NY
    9,881
    i would do lots of small stich welds moveing around to alow it to cool of inbetween welds. spread the heat out and move it around.
    good luck.
    you will be back purging it right???
    Nov 2006
    304
    Thanks everyone for your advice everyone I'm thinking doing little stitches and ill post the pictures as soon as its done. Thanks guys again!
    Mar 2007
    Bath England
    15
    Not sure on the design of your box but if you're tryin to weld open corners then maybe you could use a copper or aluminium backing bar. This can be used as a jig to keep the corner square whilst welding and will stop you burning through. Another advantage is it would act as a heat-sink which would reduce the amount of distortion.
    Just my thoughts - make of them what you will.
    Brightspark
    Nov 2006
    304
    That's what I herd I should use to reduce burn through, it will actually keep my pieces from warping as well?
    Mar 2006
    Ocean City, Maryland
    951
    Default Fun4now
    Backpurging? is that where you use a gas like Argon on the back of the weld while your welding it?? Have welded a few things out of stainless with TIG and a couple with SMAW, worked OK but didn't back purge either?? can you explain?? I have heard of it just not sure about it...Thanks
    Scott
    HMW [Heavy Metal welding]
    Aug 2006
    near rochester NY
    9,881
    yes its keepingthe back of the weld coverd in shielding gas, they also make a past you can put on the back. with thiner SS it will get all black and lose its rust preventative qualitys as well as look realy bad. not so bad on thicker stuff as the back dose not get the full heat but on thiner stuff its a prity big deal. it almost looks like you welded it with no gas.
