Results 1 to 3 of 3
Thread: Powder Coating;
    Feb 2007
    Clifton, NJ
    57
    Default Powder Coating;
    Does anyone here do alot of powdercoating on iron railings? I would like to know what is the best way to treat the steel before coating. I do fabricate alot of railing and I usaually hand paint them, and just recently customers have been wanting powder. I tell them that their is no guaranty.
    Dec 2005
    wisconsin
    830
    Quote Originally Posted by MetalCrafter View Post
    You will probably want to use a Chromate rich epoxy primer applied over fresh grit blasted iron. PC isnt the best for corrosion since it seals out oxygen from the primer and doesnt let the anodic action take place with the chromates if it gets scratched. Maybe look at a sprayed Acrylic Enamel (with hardener) topcoat. Its got better adhesion and usually better UV resistance.
    -Aaron
    Miller Dynasty 300DX
    Miller Dynasty 200DX
    Miller Spectrum 375 extreme
    Miller Millermatic Passport
    Miller Spot Welder
    Motor-Guard stud welder
    Salem ,Ohio
    3,655
    Cool
    I quit using powder coat on my outside metalwork because you can't get in the nooks and crannies with the pc and it will rust bad. I went back to painting the parts....Bob
