    Raymore Missouri
    1,920
    Default Forgot to thank FunForNow
    Thanks Fun.........Since you gave the Tip about scratching the tungsten before starting the tig arc, I have never blown through my thin material like I had been.
    Thanks again........you are an asset to the forum.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    157
    Default Scratching?
    What's scratching the tungsten?
    John
    Thunderbolt AC/DC
    MM 175
    Maxstar 150 STL
    Blue Star 185 DX
    Spectrum 375
    Thumbs up
    glad to help, just passing on others wisdom though. cant take all the credit. thanks to all the guys here .
    some times a tungsten will get frosted and not want to start the arc. scratching it like a match,( NO POWER ON)
    will help it to restart essayer.
    Raymore Missouri
    1,920
    I have a Syncro 200 tig. Some times as I would depress my foot pedal nothing would happen. No HF ...nothing. I would hit the pedal again and all of a sudden it would blow a nasty black hole through my material. Now BEFORE I hit the pedal to start the arc I lightly drag the tungsten across the workpiece
    and then start as usual with no problems. Hasn't happened again. Yeah!!!!!!
    I guess the tungsten can develope a slight coating that resist the HF start.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    2-O/A outfits
    Jet Lathe and Mill
    Propane Forge
    Queens NY
    1,547
    i have seen this problem too, the slightest touch of the tung, then the arc lights effortlessly. When it had happened in the past i thought i was seeing the dreaded dynasty high freq failure.
    Dynasty 200 DX
    Millermatic 175
    Spectrum 375
    All kinds of Smith OA gear
