Results 1 to 2 of 2
    Jan 2008
    NJ (central)
    24
    Default Mixed rare gasses
    If this topic has been covered already please disregard fellas.(I could'nt find one)
    I was just curious then about that tri mix, Argon-helium and CO2, thats also used for shielding.
    I know Argon is used on Alu whilst Argon/Co2 is used on steel. is the tri mix something that can be used on Either metals?
    and then theres them ag8 which are 8% argon or helium but a mixture of these 2 gases only, just that one is 8% of the total volume in the cylinder
    I think its Hel/Arg.
    whats that used for?
    I was just Pondering on these other mixtures. being a Noob I think its ok to ponder no?
    traded the MM180 in for a MM212
    lots room here for more machines like, a Plasma cutter oooohh yeah!
    tinkerer with many talents,master of none
    132
    Basically:
    Tri-mix is used to mig weld stainless steel.
    Argon/Helium mix is for tig. Allows things to get a little hotter.
    -James
