Results 11 to 20 of 26
    Oahu, Hawaii
    2,469
    roflmao...sorry...maybe someone that does the drill doctor method will chime in
    I'm not late...
    I'm just on Hawaiian Time
    Feb 2008
    flat , and lots of dirt
    123
    I was thinking more of repositioning the guards so that I am woking on the back side of the wheel, you know, turn the whole thing around.
    SYNCROWAVE 200
    Atlas 618 lathe (vintage 1960) reconditioned DC
    Sioux 3/8 Pneumatic Reversible Drill
    Makita Everything else
    2400 square feet of Sanford and Son lookin shop space
    "Once the spoon flys, putting the pin back in won't solve anything"
    USA 15T, 15V
    www.myspace.com/blackbird455
    http://i100.photobucket.com/albums/m...5/DSC00356.jpg two cans, one welder
    Oahu, Hawaii
    2,469
    If you can, or just take the guard off, can't see any reason why you can't work off the back of it! Make sure you wear a face shield!
    I'm not late...
    Mar 2008
    148
    Why not just install a DPDT switch on the primary windings and get the motor to spin backwards.......
    I'm going to rig up the above mentioned adapter to my belt grinder and try that. This machine has a very effective dust collection system.
    I installed this "Whole Shop" dust collection system. Noisy vacuum system is located in a shed outside along with the compressor.
    RoyB
    Dartmouth, MA
    http://www.rvbprecision.com
    Millermatic 185 MIG
    Miller Diversion 165
    Purox W200 O/A
    Grizzly 9957 Mill
    Grizzly 4030 Metal Band Saw
    Grizzly 1050 Knife Belt Sander
    Jet 1236 Metal Lathe
    TP Blast Cabinet
    Central Fla.
    311
    Default Tungsten jig
    Monte - I posted these a while back. This is a simple jig I built.
    This was all made from scrap I had in the shop and a cheap HF 6" grinder.
    Works great.
    Mar 2008
    148
    I bet this would make a nice grinder........and have lots of other uses in the shop.....only $129
    INCLUDES TWO GRINDING WHEELS
    Sharpen high speed steel or carbide tipped tools to precise tolerances. Includes water cup, light, two silicon carbide wheels.
    * Cast iron base for reduced vibration
    * Reversing switch
    * Built in mitre gauge
    Horsepower: 1/2; RPM: 3400; Wheel diameter: 6''; Max run out: 0.002''; Arbor: 1.25''; Volts 115; Amps: 6.3; Table: 6-3/4'' x 12''L; Dimensions: 15''W x 25''L; Base dimensions: 8'' x 8.5''; Weight: 110 lbs.
    ITEM 46727-1VGA
    $129.99
    http://www.harborfreight.com/cpi/cta...emnumber=46727
    RoyB
    Dartmouth, MA
    Millermatic 185 MIG
    Purox W200 O/A
    Grizzly 9957 Mill
    TP Blast Cabinet
    Mar 2008
    148
    Default Or this.......
    Or how about this.......Any advantage to slow speed wet honing?
    HORIZONTAL 8'' WET/5'' DRY SHARPENER/GRINDER
    Get your tools razor sharp! The wet wheel moves at a slow 400 RPM to provide a cool, temper-saving edge. The 5'' dry side spins at 3450 RPM to quickly grind away nicks and gouges. Includes adjustable tool rests to sharpen at exact angles and water reservoir with adjustable drip system.
    * Wet wheel: 8'' diameter, 1000 grit, 400 RPM
    * Dry wheel: 5'' diameter, 80 grit, 3450 RPM
    * Motor: 1/4 HP, 110 volts, 60 Hz, single phase
    ITEM 33867-0VGA
    $99.99
    RoyB
    Dartmouth, MA
    Millermatic 185 MIG
    Purox W200 O/A
    Grizzly 9957 Mill
    TP Blast Cabinet
    Raymore Missouri
    1,922
    Quote Originally Posted by Old Sporty View Post
    Works great.
    Looks good. The only thing I had to make was the tungsten holder. Took no time at all. I was going to do it like yours but I started grinding on the side of the wheel and in order to get all the angles figured out, this just was easier.
    What I like about yours is once you figure your grind angle out, the jig need not be changed. I stopped grinding on the edge because it was grooving my wheel and being a 6" wheel, it grinds with a radius which I don't like. I really need to get a better wheel. I hate to part with a $100 for a diamond. After I have more experience with grinding, I'll probably make my own sharpener with
    settable angles in degrees.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    26
    Default tungsten
    i use a pen vise with a 6" bench grinder
    Mar 2008
    148
    I believe you meant "pin" vise?
    That looks like a nice device. Where did you get it?
    RoyB
    Dartmouth, MA
    Millermatic 185 MIG
    Purox W200 O/A
    Grizzly 9957 Mill
    TP Blast Cabinet
