Page 1 of 3 123 LastLast
Results 1 to 10 of 26
    Raymore Missouri
    1,922
    Default Tungsten Grinder Jig
    I have been grinding my tungstens on a 6 in grinder by hand and I suck at it. No matter how steady I try to do it, it is still not even. Some have said to put it in a drill, which I have tried, but if the drill turns any speed at all, the point will be ground in a spiral fashion which I don't think will be good.
    I have a magnetic torch holder in the project gallery, made from a magnetic base indicator holder, which I used a piece of 3/8 round steel and formed it to make a torch holder. This gives infinite adjustments.
    I took the same base which will capture a 3/8 piece of round stock. I center drilled the 3/8 stock with the tungsten size I want to sharpen. In my case, I made a 1/16 in and 3/32 in x 3/4 in long dies which fit right into the tool holder adjustment jig.
    I also found a rubber plug which I drilled just close enough to hold the tungsten but still be able to slip for adjustment. This serves two purposes;
    As a depth stop and something to grip while turning the tungsten during sharpening.
    If you have your grinder on a metal table, this works great because of the magnetic base.
    With your grinder at its position, it is very easy to move the magnetic base to the exact angle and pitch you select for your tungsten tip angles.
    I hope the pictures will better explain what I am trying to say.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    Feb 2008
    Southern CT
    27
    Default Grinding Tungsten Electrodes By Hand
    Hi Monte, as I am learning tig welding from an expert tig welder, one job that he gives me (grasshopper) is to grind the electrodes. After burning my fingers, and going blurry eyed I am finally starting to have a decently ground electrode. I find that the 8" grinder gives me a larger tangential surface versus the 6" grinder. I also take the ground electrodes and put a final finish on them on a 1" belt sander that has a 120 grit belt on it. The electrodes look polished and I am starting to see the difference in the arc with a properly ground electrode versus a rough ground one.
    I did have a thought on a grinder, I was thinking of looking into one of those "Drill Doctors" that you can get at Lowes and machining an electrode holder as a function of diameter. The wheel within the Drill Doctor is a diamond abrasive so this should work when grinding tungsten.
    Any thoughts on this?
    Dennis
    Raymore Missouri
    1,922
    Default Tungsten grinder jig...last picture
    This is the last of my pictures...
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    2-O/A outfits
    Jet Lathe and Mill
    Propane Forge
    Jan 2008
    east central il
    23
    Smile tungsten grinding
    i do mine with a 4" grinder and a emery flapper wheel work slick and good enough for what i do
    Oahu, Hawaii
    2,469
    Monte,
    AWSOME PICS!!! Thanks!!!! Where can I get that clamp that goes up and down the 3/8 rod?
    I'm not late...
    I'm just on Hawaiian Time
    Mar 2008
    148
    WOW! Two great ideas in one thread..........."A twofer"
    I love using the indicator holder to get the proper angle and relief. I'm going to whip one of these up myself............
    And the idea of modifying a Drill Doctor is superb! I'm going out into the shop and get mine out right now and see if it can be modified somehow......
    Stay Tuned!
    RoyB
    Dartmouth, MA
    http://www.rvbprecision.com
    Millermatic 185 MIG
    Miller Diversion 165
    Purox W200 O/A
    Grizzly 9957 Mill
    Grizzly 4030 Metal Band Saw
    Grizzly 1050 Knife Belt Sander
    Jet 1236 Metal Lathe
    TP Blast Cabinet
    Feb 2008
    flat , and lots of dirt
    123
    Monte,
    I mentioned that I use a drill to chuck the tungsten, I run it at about 60-90 rpm, now vs a 6" wheel that is spinning at 8000+ rpm(about 12,500 ft/min) I do not get a helical finish. I finish mine with a Zirco flap wheel, then clean with berryman b-12 (tolulene, mek, acetone, all that good nervous system killing stuff).
    I like your rig though, and I will try that.
    I am also going to re-engineer my grinder so that it is not spinning towards me, I would hate to see a 3/32 piece of 7" superhard ( small diameter + high density = extremely high ballistic coefficient) tungsten propelled by a wheel moving @ 208 fps.
    Anyone have any wisdom on reversed grinding?
    What about the best wheels, that wont groove out after 5 or 6 grinds?
    SYNCROWAVE 200
    Atlas 618 lathe (vintage 1960) reconditioned DC
    Sioux 3/8 Pneumatic Reversible Drill
    Makita Everything else
    2400 square feet of Sanford and Son lookin shop space
    "Once the spoon flys, putting the pin back in won't solve anything"
    USA 15T, 15V
    www.myspace.com/blackbird455
    http://i100.photobucket.com/albums/m...5/DSC00356.jpg two cans, one welder
    Mpls, MN
    1,790
    Why not just reverse the direction you grind the tungsten in? You know - aim it down...
    You really want heavy metal dust spraying upwards?
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Thermal Dynamics Cutmaster 81
    Smith O/A rig
    Queens NY
    1,547
    I tried the drill doctor but the wheel is too small, it maked the point concave.
    Oahu, Hawaii
    2,469
    Laiky, did you use the square wheel that came with the kit? That way you have 4 sides/straight edges to sharpen before you have to change the wheel...
    I'm not late...
