Results 1 to 7 of 7
    3,952
    Cool Cast Iron Tractor Part
    This tractor part came in today with a giant cut out where the crack used to be. The part houses the steering box plus is the tank for the radiator and it froze. The guy ground it all the way thru and was going to braze it then he changed his mind. Neverless it was a large gouge. I gave it a few test tacks with some machinable cast rod and it looked like it was going to be ok so i proceded to connect the dots. Then i ground it all out and put some longer beads on it grinding between the beads as i went. I sprayed some pentrating suff on it and didn't see any cracks...Bob
    Rod info..
    Crown Alloys 255 Nickel Alloy.
    Feb 2008
    flat , and lots of dirt
    123
    DID you hear any "ticking" after the arc ended?
    I was working on a turbo exhaust case the other day and spotting it with 100 amps for maybe 1/2 to 1 second was cracking it further.
    Dug a hole in the ground, lit 5 lbs of charcoal, and blew it with my shop vac, set the casting in the middle of the heat for 25 mins until it glowed, and welded away without any cracking.
    SYNCROWAVE 200
    Atlas 618 lathe (vintage 1960) reconditioned DC
    Sioux 3/8 Pneumatic Reversible Drill
    Makita Everything else
    2400 square feet of Sanford and Son lookin shop space
    "Once the spoon flys, putting the pin back in won't solve anything"
    USA 15T, 15V
    www.myspace.com/blackbird455
    http://i100.photobucket.com/albums/m...5/DSC00356.jpg two cans, one welder
    3,952
    Nope no snap crackle pop on this part. It must have been some quality cast iron....Bob
    Feb 2005
    N.E. SD
    1,381
    Very nice work,Bob
    Jeff
    Western, NY
    31
    Don't you just love when the customer helps out. Looks good !
    Nov 2007
    6
    Default Filler rod?
    Done some cast welding myself , unless I heated the piece all I would hear is snap crackle pop! What type of filler rod were you using?
    3,952
    Quote Originally Posted by mark.902 View Post
    Crown Alloys 255 Nickel Alloy. Directions and info here.
    http://www.crownalloys.com/page10.pdf
    Preheating is not required but will make a softer weld according to the directions. But since i was not going to machine it i didn't worry about it. I have used this rod for about 10 years with no problems...Bob
