Results 1 to 10 of 11
    Feb 2008
    flat , and lots of dirt
    123
    Default Stick Welding?????
    OK,
    I realize that stick welding is the basic of welding as we know it today.
    Here is my problem........
    It is such a chaotic process, I don't know what I am doing.
    In the past few weeks that I have had my syncrowave 200, I have made some awesome aluminum and stainless welds. I started using the SMAW feature when I got some angle and needed to make a table.
    The table is securely together, made of 1 1/2 x 1/8 angle, stable enough to hold a 24 x 60 x 1/2" plate as the working surface( try walking that piece 60 feet across yer shop ) .
    My question is..............
    How DO you stick weld?
    My welds are ugly, but when tested to destruction , hahaha they fail not !!!
    The box I made of angle failed at its own corners, not where I welded ( when squished in a 300++ lb vise)
    What am I doing right, what am I doing wrong?
    What is the proper technique?
    Do you wiggle it?
    What is the right arc legnth?
    How do you know that the heat is right?
    What angle do you hold the stick to the work?
    Do you push it or pull it?
    Tell me the most basic rules of SMAW.
    SYNCROWAVE 200
    Atlas 618 lathe (vintage 1960) reconditioned DC
    Sioux 3/8 Pneumatic Reversible Drill
    Makita Everything else
    2400 square feet of Sanford and Son lookin shop space
    "Once the spoon flys, putting the pin back in won't solve anything"
    USA 15T, 15V
    www.myspace.com/blackbird455
    http://i100.photobucket.com/albums/m...5/DSC00356.jpg two cans, one welder
    Jul 2007
    Lancaster, Pa
    431
    Quote Originally Posted by Blackbird455 View Post
    Do you wiggle it?
    If you could post some pictures, that would be of great help.
    Most guys come up with their own technique. On the smaller electrodes, you may want to wiggle with something like a 3/32 so you get a wider bead on thinner metal. The correct arc length would be if you are using a 1/8" electrode, than a 1/8" arc length, same with heat, a general rule of thumb is 1/8" equals .125 so set your amps at 125 to start and adsjust it if needed. As far as the angle, it depends what position your in but for the most part, somewhere between a 45 and 90 degree angle. I use both methods when I weld, push and pull, it all depends what position I am welding in.
    Hope this helps
    Ken
    Hobart Handler 187
    Dewalt Chop Saw
    4" Air Grinder
    Die Grinder
    Rigid Drill Press
    Kellogg 10hp Air Compressor
    2009 FXDC
    Midwest
    765
    Feb 2005
    N.E. SD
    1,381
    Long ago, when High school welding class was held in a dark cave, The teacher gave us an earlier version of that book.
    It is a very good learning tool.
    Jeff
    Feb 2008
    123
    Thanks, I guess that when it comes to stick, whatever works is whatever works.
    SYNCROWAVE 200
    USA 15T, 15V
    Feb 2008
    North of Phila. PA
    404
    What rod are you trying to use? Some are easier than others. It's been awhile since I had to do stick so don't jump on me if I don't remember correctly. ( just politely tell me I don't know sh*t, I do, I just have a terminal case of CRS)
    6013, 7014, 7024 were relatively easy to run. Drag rods as you dont need to hold a arc like some of the others.
    6010, 6011, 7018 were some what harder to run. These needed to hold an arc or whip and pause with 6010.
    Feb 2008
    Southern Northerner, East of MiddleWest
    8
    Default Try 7014
    Then you don't have to worry about arc length while you learn. I started sticking just a few months ago and am getting o.k. now, you definitely CAN make a very pretty bead with stick and is thrilling when you do.
    7014 is my favorite rod because you can drag it in the weld pool, and I usually drag depending on the position. Slag is super is easy on 7014 also, though sometimes it is harder to distinguish the slag pool from the weld pool. I run 1/8" 7014 at about 95-105 amps, just adjust it until you get good penetration without excessive spatter or burn through. 6013 (for me at least) always sticks if you don't maintain proper arc length.
    Although I have no other experience with anything other than stick right now I have been reading here and on hobart and on weldingweb and on sft for months straight (8 hours a day at work, it's slow right now). One thing I have heard said is that it is very easy to make a pretty looking MIG or TIG weld that is actually a sh!tty weld. But when a stick weld looks good, IT IS!
    Nov 2007
    dallas tx
    325
    but where are the pics ????
    feel free to P/M me
    gate city virgina
    213
    Default correction
    Quote Originally Posted by DSW View Post
    I am in welding school all we use is 7018 electrodes, unless it is a root pass in pipe then we use 6010, The 7018 rod is a drag rod, u use it at a 20 degree angle and let it drag on the base metal. I run the 7018 1/4 inch rods at 115 amps and my weld looks like a machine weld **** near. The small 3/32 rod i run at 70 amps and get good results. Hope this helps.
    393
    Ok in a nutshell.
    Current.
    Angle of electrode.
    Rate of travel.
    Length of electrode.
    Electrode slection.
    Summed up as C.A.R.L.E.
    Make him your best friend no matter what process that concerns you.
    Some may know this to be the Five essentials of welding...And when the all come together..you will have a weld that cant be beat
