Try cleaning the area that you are welding with scotchbrite (no chemicals) before welding. 4130 tubing typically has a thin mill-scale on it. If you take that off you will notice a huge difference in your finished bead cosmetics and the way that it welds.
Good luck man
Brad
Results 11 to 20 of 25
Thread: GTAW welding - puddle fizzes
03-14-2008, 02:05 PM #11
03-22-2008, 06:22 PM #12
Once saw the prettiest tubing at Rausch's shop, asked the guy there what they did to it, and they said it was precision ground....so, enough said, clean that coating/scale/earl/whatever away from the site, and keep the hydrocarbons [oils] off before hand. Hope this helps,Paul
More Spark Today Please
04-30-2008, 01:57 PM #13
- Apr 2008
- Rushville IN
- 50
Puddle
I always drilled the vent hole inside of the tube, That way the whole cage was vented and there were no holes to go back and fill.
04-30-2008, 05:38 PM #14
- Jan 2007
- Pensylvania
- 16
When tig welding pipe in the field we always purged the pipes with shielding gas so when the heated gases inside would be forced out during welding it would be shielding gas not air (oxygen and nitrogen).
Just a thought.
Spar C
04-30-2008, 05:39 PM #15
- Jan 2008
- VA
- 298
Heat a section of the tube away from the vent hole with a heat gun or torch. Almost too hot to touch is good enough. Get ready to close up the vent hole and drop a wet rag on the heated section of tub. This will make air want to go in rather than coming out of the vent hole. sometimes I skip the vent hole and stop the weld and let things cool off some. I find that can close up by ether welding the last bit fast or doing the heat and wet rag trick no vent hole drilled.
05-13-2008, 03:23 PM #16
- May 2008
- 2
brake clean is the problem
I had the same exact problem when I was using brake clean to clean oil off of new steel. I discovered when I used mineral spirits or a water soluble cleaner the problem went away. One day I was out of mineral spirits and I used brake clean and the problem came back. Brake clean gets into the steel and any welding process will cause the expanding gases to blow out the weld puddle.
Hope this helps.
Best regards,Syncrowave 200
Millermatic 210 3035 Spool gun
Millermatic Passport
Blue Star 185
Thermal Dynamics Cutmaster 38
05-14-2008, 06:36 AM #17
- Mar 2006
- Queens NY
- 1,547
I would think mineral spirits would cause the problem, since its a petroleum product and leaves a residue. Now that you mention it, i think i had a problem with brake cleaner causing contamination too. I now use 100% isopropyl alcohol or in rare cases acetone and i have no more issues.
Dynasty 200 DX
Millermatic 175
Spectrum 375
All kinds of Smith OA gear
08-20-2008, 07:46 PM #18
- Jun 2007
- San Jose,CA
- 43
Definitely skip the noxious chemicals, a little emery cloth will go a long way in cleaning the tubing. As for plugging the vent holes, you have a few options... To keep the environment out, you can use a rubber plug or a pop rivet.
JohnJohn
Millermatic DVI
Millermatic 375 xtreme
And a brand new Syncro 200!!!
08-20-2008, 08:23 PM #19
- Dec 2007
- Oklahoma
- 641
08-21-2008, 11:23 AM #20
Griff,
Depends on the solution. I use either 70 or 90 percent for my cleaning, so it would be either 30 or 10 percent water. Stay away from heavy hydrocarbon cleaners, and the light ones arent good for your health. Isopropyl is just fine for 4130 and mild steel, used and accepted byt aircraft guys after years of use and testing on steel, stainless, aluminum, but NOT magnesium. Hydrocarbon cleaners have been linked to hydrogen embrittlement of 4130 when using the Tig, Mig or Arc process.
-Aaron"Better Metalworking Through Research"
Miller Dynasty 300DX
Miller Dynasty 200DX
Miller Spectrum 375 extreme
Miller Millermatic Passport
Miller Spot Welder
Motor-Guard stud welder
