I have been reading my brains out on old threads, links supplied by members etc. I have searched till I'm searched out. I have a Syncro 200 Tig(transformer) machine.
I have heard a lot of you like red(Thoriated)which are radio active, can be used on aluminum and as an all around tungsten but not the best choice for aluminum. They work but the ball seems to develope off kilter at times or small ball will develope off center if that makes sense. I didn't realize the were
radio active. Guess I should have paid more attention(thanks forum members).
I have a supply in several sizes and will use them(carefully)on steel which they are recommended and do well with DC.
What I want is a good replacement for pure(green) to be used on aluminum ac that is not ACTIVE, holds its tip, lasts longer etc. There are so many choices, I'm confused.
Anyone using a square wave machine and having good luck with a particular
tungsten on aluminum, please chime in and explain why. Thanks.
Results 1 to 10 of 28
03-11-2008, 02:41 PM #1
Another tungsten question...sorry
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
Miller Syncrowave 200 Tig
2-O/A outfits
Jet Lathe and Mill
Jet 7x12 horz/vert band saw
DeWalt Multi Cutter metal saw
Century 50 Amp Plasma Cutter
Propane Forge
60" X 60" router/plasma table
03-11-2008, 03:25 PM #2
- Dec 2007
- National City CA
- 1,086
Cerated Orange tip is the stuff to use now day's on aluminum.
I've had good results with it.
KerryMiller Syncrowave 200 W/Radiator 1A & water cooled torch
South bend lathe 10LX40
K.O. Lee surface grinder 6X18
Auto shades are for rookies
www.KLStottlemyer.com
03-11-2008, 03:29 PM #3
- Dec 2007
- 157
Free Samples
Hey Monte, can't answer you question cause I'm more green at this than you
, but look for the thread about the thoriated/safe and there is a link for some free samples someone was kind enough to attach... Maybe you can get some to try and dial in your tig.
JohnJohn
Thunderbolt AC/DC
MM 175
Maxstar 150 STL
Blue Star 185 DX
Spectrum 375
03-11-2008, 03:38 PM #4
Monte,
what Handy was referring to
Excellent info about tungstens, but they focus more on inverter machines. (Kudos to Carmen-Electra from arc-zone for this)
http://www.thefabricator.com/ArcWeld...le.cfm?ID=1276
http://www.thefabricator.com/Consuma...cle.cfm?ID=834
Free Tungsten samples from: www.Diamnondground.com
up on top, click on "request free samples). Few of the guys say they're very good also.I'm not late...
I'm just on Hawaiian Time
03-11-2008, 08:15 PM #5
When i was in collage i was told by my instructor that zirconiated tungsten works best for welding aluminum. It has a brown band but is a fair bit more expensive. I have no clue to weather its radio active or not but i hope this helps in your search.
03-11-2008, 11:35 PM #6
- Mar 2007
- Deltaville, VA
- 2,241
I'd tell ya since I've been using a Sync 250 for about 12 years, but you seem to find fault with most of my posts, so I'll keep my mouth shut.
03-12-2008, 05:58 AM #7
- Jan 2008
- VA
- 298
I too have a transformer based Syncro 250 and am watching this thread. It seems that the more you read the more answers you get as to the latest "best" tungsten alloy to use. Pure with a ball, Red with a point, Red with a blunt tip, Orange with a point or a blunt tip, long angles, short angles, caffeinated decaffeinated, great taste, less filling?
It is hard to filter the advice in some books or online as it often starts out general but often ends up aimed at the inverter machines and things get unclear.
Right now I am using good old green with a ball. I can make things that stay together until the check clears at least but I am no ex-purt by any measure and always want to improve my skills and methods.
What is the latest advice for transformer machines on aluminum? I have to admit I am getting addicted to welding up aluminum. When it goes well it is satisfying because it takes knowledge and skill and is not just point and shoot.Weekend wannab racer with some welders.
03-12-2008, 06:59 AM #8
OH gosh....here we go again!
MONTE...this is as close as I can put my OPINIONS into words.
This is transformer info tho it relates to everything just in varying degrees.
GREEN is crap...it just goes into thin air compared anything else. I wonder what it was ever compared to?
RED is the standard that everything is measured up against. I find by using it all day on AC on aluminum which I do everyday like it or not it will make a ball on the tip nicely. But it will begin eroding away and start making several little b@ll$ and then splitting etc. If you consantly dip your tungsten or touch your filler then it would be fine cause you'll be grinding before it cycles out.
BROWN.... is the ultimate OLD SCHOOL stuff. (for aluminum) It makes a nice ball on the end and will last forever untill you dip. It will even go after that if it is a light touch as will most tung. But brown is the best at cleaning itself IMO. IT would be my first choice to use if I was wanting to knock out a bunch of work as fast and maintenance free as I could and was using a transformer style machine. You just keep pulling it out as it wears away. When you want a more focused arc with a point then you begin to look into more exotic metals.
ORANGE...welds great and will hold a point on a transformer longer than most.
If you are wanting to get the most out of your syncrowave then this is a great choice to use because it will weld all day without splitting.
GOLD....I find this about the best and is what I currently use. it is now readily available and will replace all colors. It will hold a ball nicely and will hold a point nicely. I holds up better than orange at high amps. It is 1 1/2% lanthanated and BLUE is 2% lanthanated but blue is much harder to find.
Using lanthanated will cause you to let all your other coller to just sit and collect dust. So go get it NOW before you sink more money into all the other colors that you will never use once you get into this stuff.Miller Dynasty 700...OH YEA BABY!!
Miller Bobcat 225 NT
Miller 30-A Spoolgun
Miller WC-115-A
Miller Spectrum 300
Miller Spoolmate 200
Miller 225 Thunderbolt
SPEEDGLAS 9100XX
03-12-2008, 09:18 AM #9
Have no idea what you're talking about. If you had a post and I disagreed,
so what? I am allowed to state my opinion as anyone else, even you. If you don't want to share information........don't. I don't know what posts you're
talking about or do I care now. That's old business. I try not to remember
problem posts, but I guess you do. Remember this.......you haven't just held
back information from me, but the entire forum. Does that actually make you feel better?
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
2-O/A outfits
Jet Lathe and Mill
Propane Forge
03-12-2008, 09:26 AM #10
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
2-O/A outfits
Jet Lathe and Mill
Propane Forge
