Page 1 of 3 123 LastLast
Results 1 to 10 of 26
    Dec 2006
    New Jersey
    779
    Default Need a speed control to reduce my chopsaw speed.
    Anyone know where to get a variable speed motor control to drop my 115volt 15 amp ac chopsaw motor from 3900rpm to 1600rpm or so? I am looking to run some of my Dewalt carbide metal blades for some nice clean cuts versus the standard metal cutting blades and don't want to damage them with the high speed. Thanks. Dave
    Mar 2006
    Queens NY
    1,547
    i have a router speed control that worked briefly, until the fuse blew, not made for chopsaws, the problem is that you don't have the torque once you reduce the speed.
    Nov 2007
    dallas tx
    325
    i think you could just wire in a rheostat
    my daddy always said i was IRONHEADED....
    feel free to P/M me
    Sep 2006
    Washington State
    73
    Default dumb ***
    you can not do this!!!!
    those saws are not designed to cut at a slower speed and the motors are not built to handle the stresses that carbides produce. they are more agressive and grab when cutting.
    trailblazer 280 nt with 3000 hrs and running strong
    today I bought a new trailblazer 302
    and a new s-32p
    dynasty 200 dx
    maxstar 140
    passport
    XR pushpull
    spectum 500
    cutmaster 50
    Dec 2006
    New Jersey
    779
    The guy at Sharp-rite where I bring my wood and metal blades to get sharened says he has seen it done quite often. He mentionaed a speed control that you can get through a woodworking magazine but I couldn't find what he was talking about. The Dewalt carbide I have definitely cuts alot "easier" than the disposable type wheels. I guess this is because it "machines" the metal when making a cut versus grinding it. And the nice thing is the metal doesn't get hot. But, I was using the blades at 3900 rpm not realizing max speed was 1800rpm, so you can ultimately see why they didn'rt last as long as they should . Speed=friction=heat. Anyways, if I can't find anything online I'm just gonna drive back to him to see what the piece was called. Thanks again. Dave
    Baldwin, NY
    275
    Grizzly sells a router speed control, but your chop saw motor WILL burn out if you use a carbide blade and reduce the speed in half. Not Might, it will. I went through two saws this way, then broke down and bought a bandsaw. I will eventually buy a cold cut saw made for the purpose as well, but since I had to cut some 8" and 9" beams, it only made sense to get the bandsaw. Best money I have ever spent. The cut quality is between an abrasive and a cold cut, almost as nice as the cold cut carbide saws.
    Not trying to be a downer, but if you want to waste $50 on a speed control, and then have to buy another saw soon to replace the one that gets burnt up, its up to you.
    Voigt Precision Welding, Inc.
    Miller Dynasty 200 DX, Miller Syncrowave 250, MillerMatic 252, Hypertherm Powermax 45, Auto Arc Trailpower 8000,272+187 lb Peter Wright anvil, 120 lb Fisher-norris, and more! Buffalo drill press, Grizzly Horiz. Bandsaw, Edwards shear, Barth Shear, bantam mechanical ironworker, Hopkins fly press, Doall Bandsaw, brown and sharpe surface grinder.
    2007 Silverado 2500HD (tow vehicle)
    2000 Camaro SS (Race car)
    Mar 2007
    Deltaville, VA
    2,241
    Dave,
    Listen to what some of the other posters have told you.
    A speed reducer for your abrasive saw is not the solution. Reducing the speed also reduces the torque. You WILL (not may) burn up a perfectly good chop saw.
    Porter Cable, Milwaukee, Makita, etc all make cold cut saws designed to operate at the speeds dictated by carbide blades. I understand that Evolution (looks like a Porter Cable) also makes a 14" cold cut saw which Sears sells for in the $270 range. If it is indeed, a rebadged PC, it is a good saw.
    The cold cut saws are well worth the money. You'll want to keep the abrasive though, since the cold cut saws arn't recommended for re-bar or other "mystery metal" such as bedframes.
    Check out FleaBay, since there seems to be a big markup on the saws.
    Dec 2006
    New Jersey
    779
    Thanks for the advice guys, gonna look into the Dewalt cold cut saw. Really liked that one. Anyways, definitely appreciate the help. Dave
    Dec 2006
    New Jersey
    779
    Anybody have any decent online places to buy these? Good prices and good service? Thanks. Dave
    Mar 2006
    Queens NY
    1,547
