Results 11 to 16 of 16
    Raymore Missouri
    1,922
    Also turn the balance up and I'd certainly loose the red.
    Why do you say lose the red? What do you recommend? The reason I am using red is so many have stated that's all they use and pure tung (green) doesn't hold up as well.
    I switched to green last night and noticed that the ball on the end of the tungsten is about the size diameter of the tung or slightly larger and the ball stays shiney.
    The red would develop a ball but much smaller and you can still see the grind
    angle of the tungsten.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    Seattle,WA
    55
    I've always used lanthanated(yellow) tungstens on aluminum, and red on steel and stainless. Yellow forms a ball but still keeps some what of a taper on it.
    Welders do it hotter!!
    www.Munsonworks.com
    Lake of the Ozarks MO
    3,594
    I guess if the red is all you have then use it...I'm not much of a green lover either...it just goes away too fast for me. I don't like red because it eventually erodes too bad and grinding happens too much for me.
    I much prefer to use the lanthanated on everything nowadays. It holds up well both AC and DC and doesn't erode as bad as red on AC.
    I also like the smaller filler for the thin stuff.
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Jan 2008
    Colorado
    673
    Smile
    When using 1/16" filler, you'll need to keep a steeper torch angle. If your push angle is too steep, the heat will melt the filler before it gets to the puddle. This isn't a problem with 3/32".
    RETIRED desk jockey.
    Miller Syncrowave 250.
    157
    Default different subject...
    Hey Monte, didn't you post something about a hovercraft somewhere from days of old? Any pictures. I always had a thing for hovercraft...
    Thanks,
    John
    Thunderbolt AC/DC
    MM 175
    Maxstar 150 STL
    Blue Star 185 DX
    Spectrum 375
    Raymore Missouri
    1,922
    Quote Originally Posted by Handy560 View Post
    Thanks,
    Yep, that was me. I'll try to find the pic
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    2-O/A outfits
    Jet Lathe and Mill
    Propane Forge
