Results 1 to 10 of 20
    Jan 2008
    Most likely in Florida
    111
    Default Good advice for those that weld aluminum
    If you think your aluminum welding skills have suddenly taken two steps backwards...
    Check to make sure you didn't pick up a 308 stainless steel filler rod by mistake.
    And, no Craig. You may not post in this thread.
    Jan 2008
    VA
    298
    "Boy, this Al filler rod sure is stiff"
    How about a "Dumb stuff you have done while (trying) to weld" thread for stuff like this and my gas mix- mix up. I bet there are some good ones.
    Feb 2008
    Seattle, WA
    22
    Forgetting to turn the gas on with the mig is a fun one. It's amazing what a difference a little shielding gas can make.
    Jan 2008
    111
    Quote Originally Posted by Vicegrip View Post
    Hehehe.
    And it was fighting the heat. Didn't want to melt into the puddle. When I would try and put it in, instead of melting it would poke a bigger hole into the joint.
    Jan 2008
    111
    Quote Originally Posted by jonsam View Post
    Indeed. I did that recently as well. I had shut off the gas because I was about to stop for the day. Went inside for a few minutes, then realized I had a little time left, so went back into the garage and started to weld again. Forgot about the gas. Oops.
    I should shut up now or else nobody will ever hire me.
    612
    I've run the argon tank empty. Same result as forgetting the valve, just more gradual.
    Midland, Mi.
    313
    Quote Originally Posted by root View Post
    HA! HA! Been there, Done that!
    Jan 2008
    8
    how bout using acetylene as the shielding gas?? anyone done that?? I thought I saw a thread about it somewhere.. hehe
    Crossville, TN
    87
    Another tip.... do not store your magnesium rods within10 feet of your aluminum rods.
    Indiana
    541
    Acetelyne tanks have lefthand thread to prevent just such a thing.
    Tim Beeker,
    T-N-J Industries
    (my side bussiness)
    Esab 450i with wire feeder
    HH135 mig
    Miller aircrafter 330 - sold
    Marathon 315mm coldsaw
    table saw
    Dewalt cut off saw
    Sand blast cabinet
    lots of hand grinders
    Harris torch
    beer fridge
