Results 11 to 12 of 12
    Indiana
    541
    Talking
    A uni-body is totally different from a vehicle that uses a perimeter style frame. With a full frame under the car you can take various parts of the body, or the frame, and replace them as long as you jig everything up so it goes back together straigt. A uni-body on the other hand is its own frame, once it has been comromised it will never achieve its full strength again. The various components of vehichle with a frame are sort of like lego, while a uni-body is more like a plastic molding, if you will. There's a reason insurance companies right off newer cars that don't LOOK that bad. Mabye if it was an original numbers matching 69 COPO Camaro...
    __________________
    If it were a COPO, even a 9561, then he could sell the car a buy a brand new one!
    Tim Beeker,
    T-N-J Industries
    (my side bussiness)
    Esab 450i with wire feeder
    HH135 mig
    Miller aircrafter 330 - sold
    Marathon 315mm coldsaw
    table saw
    Dewalt cut off saw
    Sand blast cabinet
    lots of hand grinders
    Harris torch
    beer fridge
    Jan 2008
    VA
    298
    You will also find that when you cut you will likely be looking at layers of metal in many areas. If you only present 2 large sections together you can only see and weld the metal on the surface in that area. There might be 3 or more layers of metal inside. "A" and "B" pillars, sills and rocker areas are examples of complex areas.
    I just finished up removing a roll cage from a wrecked Porsche race car and presenting it to its replacement body. We cut the top off of the old car to ease removal of the existing cage and the "A" and "B" pillars were 5 or 6 layers of vairous thickness metal. I know of another car of the same model that a guy cut the top off in the same place and welded it back on. He even ground the welds down to hide them. Looks like new but I would not want to be in that car in a wreck.
