if I cleaned the metal befor using 6011 or 6013 would I get more penatration or would I have to use a diferent type of rod? just wondering
Results 1 to 10 of 11
Thread: Stupid question! Realy!
03-03-2008, 07:20 PM #1
- Jan 2008
- haslet, TEXAS
- 109
03-03-2008, 07:31 PM #2
6011 or 6013
These two rods are in different leagues of penetration. 6011 has a lot. 6013 has a little.
HTH
Triggerman
Ammonia refrigeration tech
Millermatic 180 w/Autoset
CST-250
HF-15 High frequency
XR15 w/Push-Pull Gun
03-03-2008, 07:33 PM #3
- Aug 2006
- 3
AC or DC, 6011 will run better with AC, 6013 with dc, and clean metal. What are you welding? BTW cleaner is always better.
03-03-2008, 08:08 PM #4
- Jan 2008
- haslet, TEXAS
- 109
Ill probably be running ac. I was thinking of building a trailer. Maybe kind of like rbertalotto a few posts down from here. I want to get maxmum penitrarion because I'll be carrying my golf cart and didn't want it falling off>(it's my baybe)
03-03-2008, 09:23 PM #5
If you have a DC power source with sufficient kick, running 6011 DCEP will give you the most penetration. 6013 is a lower penetration rod designed for general purpose, lighter gauge work.
No matter what rod, or what you are working on, it is always good practice to have you base metal as clean as possible.
Dynasty 200DX, first generationMakita 5" grinder
Makita 14" abrasive sawIR SS5L compressorWhole bunch of hand/air tools.and a wish list a mile long
03-06-2008, 07:36 PM #6
- Mar 2008
- Lockport, NY
- 17
What rod for best penetration on AC?
6011 is the best rod for penetration on AC. It also is more forgiving for dirty metal and good for filling in gaps with the fast freezing puddle, utilizing the whip technique. As was mentioned the cleaner the metal is always better for any welding process.
Skip
03-06-2008, 09:29 PM #7
Clean surface..
If asking if cleaning the metal will help penetration, absolutely! It's a proven fact and it only makes sense as you increase the conductivity with a clean surface which in-turn delivers more current to the work surface. Stick has always been a good choice in wind and on surfaces that are less than clean due to the mass (size) of the electrode (wider area of contact). But as mentioned above all electrodes differ from one another and as mentioned above, the 6011 delivers the most penetration in all weldable conditions.
My 2 pennies worth, good luck..
TacMigWe depend On:
Burco/Koco | Onan | BobCat
We belong to or support:
American Welding Society
The Welding Institute
Anderson & Co. LLC
Metal Crafters
03-06-2008, 11:16 PM #8
Definitely.
And, I'll take issue with some of the advice you've been given.
IMO, 6010/11 runs best on DCEP. Both of those rods are difficult on AC. 6013 runs really sweet on DCEP. While it is a high titania rod (soft arc, shallow penetration) it is certainly adequate for any trailer frame I've ever seen with good joint prep.
If all you have is AC, I'd recommend EXX14. It gets medium penetration, runs nicely on AC, and is easy to clean up.
Also, there are no stupid questions!
Hank...from the Gadget Garage
Millermatic 210 w/3035, BWE
Handler 210 w/DP3035
TA185TSW
03-07-2008, 05:49 AM #9
Correctomundo
We depend On:
Anderson & Co. LLC
Metal Crafters
03-07-2008, 10:31 AM #10
ACXX14 would be a good choice. 6013 has never been one of my favorites but I know alot of guys that swear by the stuff. 6011 is a good all-round rod for most applications, and will run well on AC or DC. However, if you have a machine with DC capabilities, pick up some Lincoln 5p+ 6010, won't run for **** on AC but on the DC side it can't be beat. At work on the old Forney, I use 1/8" 6011 (110-135 amps AC) on most applications, or 3/32" 7014 (85-100 amps AC) on the smaller stuff. When I have access to my Thunderbolt, I use the 5p+, 1/8" 6010 (110-135 amps DCEP), and cap that with 1/8" 7018 low-hydrogen (135-150 amps DCEP). Good surface prep is always a good idea. Hope this helps
At Home
Miller Thunderbolt XL AC/DC
Performance Tools 6" Bench Grinder
Craftsman Hand Tools
Craftsman Cordless Drills
DeWalt Angle Grinder
1976 AMC Jeep CJ7
1980 Ford F150 Custom
1994 Chevrolet Silverado C1500
At Work
Miller Bobcat 250
2 Miller MM251s
2 Miller MM252s
Miller Dialarc 250 AC/DC
Lincoln Idealarc 250 AC/DC
Snap-On Flux Core Welding Machine
Hypertherm Plasma Cutter
Victor Torches
2006 Chevrolet Silverado 2500HD 4x4
Proud American Ham KE5TJA
