Results 1 to 10 of 13
    Nov 2007
    Jackson, MI
    57
    Default Need help selecting a belt sander.
    Im about to buy a new belt sander and torn between two different units. I am mostly rounding corners and edges on 1/4" flat plate and deburring tubes after cutting them in the bandsaw or cutoff saw.
    #1 Kalamazoo S4S, 1HP. 4x36 belt. Turns 3450 RPM. Made just an hour from my house by a very reputable company. $780.
    http://www.kalamazooindustries.com/belt_sanders.asp
    #2 Wilton 4210K, 1HP. 6x48 belt, 10 disc. Turns only 1650 RPM. $649. Import.
    http://www.hechinger.com/web/catalog...4E6197FF702A75
    Obviously I get more for my money with the Wilton unit. But Im concerned about the speed of the belt. If its turning only 1/2 as fast, the belt would probably be much more likely to catch and rip, right?
    Not sure which way to go here guys. Anybody have either one? Any advice is appreciated.
    Jul 2007
    campbellsville ky
    953
    i have a ellis and all i can say is i love it.i use it all the time.pep at ellis told me it would sharpen a 3/8 rod to a pencil it about 10 seconds and it will.i cant brag it up enough,all i can say is i would highly reccomend you at least give em a look.i also should note im still on the original belt,with about 2 to 3 hrs of grindin time.
    Oklahoma
    743
    Quote Originally Posted by ck welding View Post
    I had the Wilton first. Gave it to my son for hobby woodworking and bought the Kalamazoo. Two times the cost that way but I am happy with the Kalamazoo sander.
    Griff
    Nov 2007
    Jackson, MI
    57
    Quote Originally Posted by weld-tek View Post
    I have literally hundreds of hours of use with that exact machine - back about 10 years ago when I made money the hard way. I agree, its a nice machine.
    Nov 2007
    Jackson, MI
    57
    Quote Originally Posted by griff01 View Post
    Griff
    Not enough power, or what?
    132
    RPMs don't matter as much as SFM (Surface feet per minute). The larger sander probably has larger rollers, which turn faster(SFM) at a given rpm.
    My point is that the SFM of the two machines could be equivalent or at least closer than than the RPMs suggest.
    -James
    Oklahoma
    743
    That's right. It would bog down when sanding metal. The Kalamazoo does not.
    Griff
    Feb 2008
    Western NY State
    41
    Smile Belt Sander
    I suggest you take a look at the Bader with 2x72 belt. I have one and a knock off that I built to use the Bader wheels. The knock off has cone pulleys so the belt speed is adjustable. Bader make a variable speed machine also. The Bader has numerous attachments for various purposes.
    www.stephenbader.com
    26
    Default sanding
    i was looking at grizzlys 6x48-12 #g1183
    ive herd a lot of good about it and its $525.00
    and its 110/220
    Apr 2007
    348
    Another vote for Ellis, but they are expensive at around a thousand dollars. I order replacement belts custom made from the sandpaper division of Woodworker's Supply and they are resonable. I'm surprised at how long belts last on these machines.
    To go with a stationary unit, I have a Bosch variable speed hand held 4x24 sander that I run 36 and 40 grit on. You can turn it down to it's lowest speed and make the belts last and work more effective on metal and it still has enough power to keep from bogging down. I've had that tool for years and it's blended countless welds for me. I order those belts in boxes of 10 from the same place. It cost me about $1.75 per belt.
    Millermatic 35
    Miller TB302G
    Ellis 1800
    Smith & Victor Torches
    Optrel Satellite
    Arcair K4000
    Ingersoll-Rand 175CFM Diesel Air Compressor
    Home Made Welding Trailer
