Results 1 to 10 of 11
    Jun 2007
    Reno, Nevada
    31
    Default What size generator to power a Passport Plus?
    What size generator would I need to power my Passport Plus on the 220 setting? Thanks.....
    Nov 2007
    Central Idaho
    205
    Default Generator size
    I use a 5100 watt/6350 surge that runs my Passprt Plus and Maxstar 150 at max amps without breaking a sweat. It's a Coleman Powermate w/ 10 hp Subaru engine. I had a Powermate 5100 watt but it had a Briggs and Stratton engine that would not start much below 30 degrees. Small engine repair guys I talk to say to stick to Subaru or Honda engines.
    I bought mine for about $500 at Costco. You can pay a lot more, but this sure works for me.
    Jun 2007
    Reno, Nevada
    31
    Default thanks.....
    Mike thanks for the reply. I will look into what you have suggested.....
    Dave
    743
    Question ? For mikeswelding
    Quote Originally Posted by mikeswelding View Post
    Would your Powermate 5100 watt with the Briggs and Stratton engine power the welder? If so was the only reason you changed generators due to the cold starting issue? The reason I am asking is that I also have a Powermate with a Briggs that I was going to use as a power source.
    Thanks,
    Browns Valley, California
    1,713
    Quote Originally Posted by kiwi View Post
    Thanks,
    My Coleman Powermate 5KW with a Briggs & Stratton 10-hp engine runs any 20-amp machine I plug into it.
    Hank
    ...from the Gadget Garage
    Millermatic 210 w/3035, BWE
    Handler 210 w/DP3035
    TA185TSW
    Nov 2007
    Central Idaho
    205
    Thanks,
    It powered the welder as good as the Subaru. Only problem is I live in the mountains in central Idaho and kept the generator in the back of my truck for onsite jobs. I would have to take the Briggs & Stratton unit out of the truck and warm it up in my shop before it would start. I have not had that problem with the Subaru engine.
    I also had a problem with the unit running at full rpm when it was new. It was covered by warranty, but it was a big hassle because the closest authorized repair center was 80 miles away.
    Jun 2007
    Reno, Nevada
    31
    Default Generator
    Mike I picked up a 5000 watt/6150 Surge Coleman with 10 HP Subaru motor at Home Depot tonight for $520.00. How loud are the Subaru motors compared to the Briggs?
    Jun 2007
    Reno, Nevada
    31
    Default Spectrum Extreme Plasma 375
    Hey can someone help me out with my plasma recommendations for power..... :
    Here is what it says in the manual..... :
    Input Amperage Circuit Requirement
    * A 120 volt, 20 amp (min.)
    - 30 amp recommended or 230 volt, 15 amp (min.) individual branch circuit
    My new Coleman generator is 20 amps on the 220 volt. So will it not run the plasma efficiently on 220? Thanks....
    Oahu, Hawaii
    2,469
    ProWorkz,
    If it's new, can you take it back? or have your wife take it back? just explaing to them that it doesn't have the requirements you need to run your machine and get a bigger one...
    hope they exchange it for you! Any 220v welder usually needs at least 30amps. You'll probably keep tripping the breaker....
    I'm not late...
    I'm just on Hawaiian Time
    Jun 2007
    Reno, Nevada
    31
    Default Welder
    Hey Bert, thanks for the reply.
    My Miller Passport says it only needs a 20 amps 230. I bought the generator just to power my welder if I need to weld out in the field on one of my dump trucks. Some of these guys on this post say there 20 amp 240 plug on their generators run their 220 passport with no issues. Now I am confused.....
    What do they mean by 230 volt, 15 amp min on a individual branch circuit. Wouldn't the generators 240 volt, 20 amp plug be a individual circuit?
