Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 43
  1. #21
    Cleveland, Ohio
    38
    A friend of mine uses "Stargon" from Praxair for the stainless that he uses in his sculptures. He dosen't know what the mix is though. You could google it though.
  2. #22
    Oahu, Hawaii
    2,469
    Default Pickling
    James,
    LOL, sounds like Cliff on Cheers....my mind is like that too! Whish I was like
    Dumbledor in Harry Potte and put/save my useless thoughts in the pensive
    I'm not late...
    I'm just on Hawaiian Time
  3. #23
    Oahu, Hawaii
    2,469
    Default tenfingers
    thanks for the tip, I'll look it up later
    I'm not late...
  4. #24
    Feb 2006
    Sacramento CA
    80
    I have a little Lincoln SP100 w/.023 SS and tri mix that works quite well for the little SS I do.
  5. #25
    3,658
    The Stargon SS Shielding Gas, a mixture of argon, carbon dioxide, and nitrogen, is designed for joining a variety of stainless steels under the most ...
    findarticles.com/p/articles/mi_hb4400/is_200306/ai_n15309992 - 29k
  6. #26
    Oahu, Hawaii
    2,469
    thanks Bob
    I'm not late...
  7. #27
    Feb 2008
    835
    Default Almost every place has 240V or 208V
    I have a secret weapon... I made a welder plug with 2 25' 12ga extension cords going into it. Both neutrals are tied to the center leg, and each hot is tied to the outter legs. The other ends of the cords have standard 120V male plugs. Plug it in one outlet and plug it into another outlet on a different circuit. If it's a residential or commercial 120/240 1 phase service, 50% of the time, there will be 240V across the two hots. If not, try another plug on another circuit.
    If it's commercial 120/208 3 phase, 67% of the time, you will get 208V. If not, try another plug.
    You will get enough power to run a good size welder or plasma cutter.
  8. #28
    157
    How safe is the secret weapon? I guess it depends what exactly you plug into and that the equipment is auto line sensing...
  9. #29
    Oahu, Hawaii
    2,469
    Bodybagger,
    thanks for your tip, I REALLY appreciate it, but you just scared the SH*T OUT OF ME
    I think I'll stick to the "regular" pigtails
    bert
    I'm not late...
  10. #30
    fuse tig the seams. Done tons of stainless work and all I have ever done is fuse it. My old shop had a 12ft wide hydrolic brake and we bent them up in house to avoid having to use seam sealer. You do not want to use that in this application. It will collect food and crap and defeet the purpose of having S.S. countertops.
    Get the stuff bent up then do the welding and finishing yourself.
