Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
  1. #21
    Jul 2007
    Lancaster, Pa
    431
    Even though the drilling and pinning or set screws is more time consuming, it may be the answer in the long run. Being the only welder in 2 crews of 30 guys, this would free me up so I don't get backed up on my other work. I could always weld the critical ones if necessary. Anybody or should I say ALMOST anybody can drill a hole and drive in a drift pin or set screw. This would also prevent any lead from seeping out by welding. As far as leagage, thats no concern if you ever see how they leak when the fire department uses them.
    Ken
    Hobart Handler 187
    Dewalt Chop Saw
    4" Air Grinder
    Die Grinder
    Rigid Drill Press
    Kellogg 10hp Air Compressor
    2009 FXDC
  2. #22
    Raymore Missouri
    1,920
    Since the adapters are going to be attached with the idea of not being removed........drilling one maybe two 1/4" holes and pin should be an easy job. Cast and brass........easy to drill. Unless your pay is determined by time spent..do the easiest. Tapping is too much trouble.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
  3. #23
    May 2005
    600
    Quote Originally Posted by KBar View Post
    Kbar, it's your deal and if you're cool with pinning that's fine. question is how much 'meat' is available for the pin, having not seen the adaptors, do you have to pin through the thread?
    also, the heat input from a SMAW would be miniscule and wouldn't affect the lead.
  4. #24
    ****inson ND
    557
    Talking
    I agree withh pumpkinhead. You wouldn't do much more than just warm up the potential lead inside the hydrant and it requires little time and effort to do. 2-1/2" to 3/4" long beads 180* appart would be plenty.
