Page 1 of 3 123 LastLast
Results 1 to 10 of 24
    Jul 2007
    Lancaster, Pa
    431
    Default Need Help With Brass
    Here is the job I am facing once the weather turns warmer, where my manager sees time in my schedule, I have no idea. We have about 45 - 50 fire hydrants left in town where the threads on the outlets do not match up to the new fire trucks. All the threads are brass on all hydrants. They are buying adapters to fit the hydrants so the fire department can just hook to them without using their own adapters, these adapters are brass also. The barrel of the hydrants is cast iron so the brass insert was molded in somehow when the hydrant was made. The newer ones have set screws and are removable. They want me to braze or weld the $200 adapters fast with about 1 inch of weld to prevent them from coming off, theft or otherwise. The brass is about 1/4" thick and the threads stick out about 1-1/2" past the barrel of the hydrant. They have a generator, stick welder, mig welder, torch outfit that I can easily mobilize to do the task.
    Can anyone offer any suggestions on what the best methods would be or should I get a list of compounds before hand that were used in the manufacturing of these items ? I know its going to be expensive but then looking at the initial cost of the adapters - $200 x 50 = $10,000, welding supplies will be cheap
    Ken
    Hobart Handler 187
    Dewalt Chop Saw
    4" Air Grinder
    Die Grinder
    Rigid Drill Press
    Kellogg 10hp Air Compressor
    2009 FXDC
    Central Fla.
    311
    Default Braze 'em
    I would suggest you braze them with either oxy/acet or a tig machine.
    You won't have a metals incompatibility problem and the strength will be there.
    Just my $02.
    Quote Originally Posted by Old Sporty View Post
    Just my $02.
    how do they use a tig machine to braze or weld brass? or even copper? do you use brass filler ? and what tungsten would you use?
    3,948
    I 2nd the torch weld. But is there any rubber packing in the hydrant that will melt or burn? You could do a little vee grind between the brass and the cast iron and fill it in with braze...Bob
    Jul 2007
    Lancaster, Pa
    431
    The only rubber would be where the stem sticks out the top of the hydrant or about 4 - 5 feet down the barrel where the hydrant hooks onto the water main, there is a rubber gasket around the plunger that seals off the water.
    The one concern I did have with brazing is with brass being a good conductor of heat, would it transfer too much heat to the cast iron causing it to crack ?
    Ken
    Hobart Handler 187
    Dewalt Chop Saw
    4" Air Grinder
    Die Grinder
    Rigid Drill Press
    2009 FXDC
    Dec 2005
    wisconsin
    836
    I take it the adapters thread onto the existing fitting on the hydrant? Dont shoot me for being in left field here but, why not use something along the lines of Loctite High Strength Bearing Mount with Primer N on the threads before assembing it? With the ammount of force required to break it free, its basicly permanent, and helps seal. We use it at work for all of out large fittings. Just a thought.
    -Aaron
    Miller Dynasty 300DX
    Miller Dynasty 200DX
    Miller Spectrum 375 extreme
    Miller Millermatic Passport
    Miller Spot Welder
    Motor-Guard stud welder
    Fraser Valley, BC
    593
    I could be wrong, but you can tig brass can't you? Pretty sure the big whistle my shop teacher was working on was brass, and the entire round end cap was welded on.
    Don't know if it would be the best for your application as the threads should be watertight on their own. It sounds like you just want to keep it from coming off, if thats the case the threads should make an excellent fit for brazing. Got any pictures?
    Makita 5" grinder
    Makita 14" abrasive saw
    IR SS5L compressor
    and a wish list a mile long
    Central Fla.
    311
    Quote Originally Posted by mikesparks View Post
    Brazing with Tig is the same as using o/a. The tig torch is just the heat source. I'm no expert at this, but have done a little bit of it. Heat control is the main thing to watch. Don't want to boil the brazing material and don't want to overheat the base material. Requires a good touch.
    I'm sure there are some of the long time weldors here that have run across this in the past. Just get some scrap and give it a try. Another skill to learn.
    Feb 2008
    8
    Brazing with a o/a torch would be best. make sure that there are not any other materials in the hydrant that can be hurt by the heat. if the fitting can be removed from the hydrant before brazing, that would be a plus.
    Nov 2007
    184
    If these are just thread on adapters I'd be inclined to
    heat the adapter up to say 350-400 degrees and thread it
    on while hot. Would suspect when cooled it would not be
    able to be unthreaded with out breaking the original stub
    out of the cast barrel.
    Dave P.
