Results 11 to 20 of 28
Thread: Nascar Chassis's
02-29-2008, 11:18 PM #11
03-01-2008, 09:14 AM #12
Member
- Jun 2004
- Massachusetts
- 38
life expectancy
The main rails and cage can last a season or more. The front and back halfs get repaired/replaced frequently.
03-01-2008, 12:29 PM #13
- Dec 2007
- 18
DOM is also Mild Steel. The difference from DOM to ERW is DOM stands for draw over madrel were as Electro resistance welding ( think I got that out right). DOM uses the same process to be formed as 4130 chromoly hence the reason for the steep price increase from it to the ERW steel. ERW steel starts off as flat strap and is them formed then pressed together and squeezed together then hit with some power to get it to stick.
Now why use Mild steel instead of moly. One you have a weight rule so why run a lite weight car when you then have to bolt on so much lead. Mild steel can be just as stong as chromoly only draw back is you have to use upwards of 30 percent more wall thickness to get it there. Second I know of is the response of mild steel. It is more forgiving as far as spring back. Now to not get in to some great detail but can you imagine a sprint car that has to do 200 laps the drivers would be wore out.
03-01-2008, 01:47 PM #14
Miller Dynasty 300DX
Miller Dynasty 200DX
Miller Spectrum 375 extreme
Miller Millermatic Passport
Miller Spot Welder
Motor-Guard stud welder
03-01-2008, 03:46 PM #15
RETIRED desk jockey.
Miller Syncrowave 250.
03-04-2008, 07:54 PM #16
maybe so but if a sprint car had the same suspension as a stockcar it would make it be a much different beast.
03-04-2008, 10:15 PM #17
03-06-2008, 09:23 AM #18
- Apr 2005
- Saskatoon, Saskatchewan
- 220
Thermal Arc 185TSW, Lincoln SP135+, 4-post automotive hoist, 2x media blast cabinets, 50 ton press, 80gal air compressor, 4-1/2"x6" bandsaw, 4'x4' Torchmate CNC table with plate marker, Hypertherm Powermax 65 plasma cutter, ultrasonic cleaning stations
03-08-2008, 09:55 PM #19
- Jun 2007
- 482
DOM is ERW. The difference between the two is DOM has been drawn over a mandrel but up to that point they are both formed and resistance welded in the same ways. ERW and DOM are both ASTM classification A-513. DOM is most often A-513 type 5 with type 5 meaning "drawn over mandrel". 4130 can be A-513 type 5 too, but it's most often A-519 which is true seamless tube meaning it is drawn into a hollow round by piercing solid stock. Mild steel can be A-519 as well, but that's not as common as finding it as DOM.
Also, mild steel is not more "forgiving" as far as "spring back". While spring back is not a technical term, 4130 as a material will deflect farther than mild steel (such as 1010, 1018, 1020, etc.) and still return to original shape.
Also, if 4130 was subbed for mild steel and wall thicknesses lessened to maintain the same amount of yield strength the 4130 chassis would be LESS stiff than the mild steel chassis which would have more material and thus be the reason the mild steel chassis is stiffer. This is all covered heavily in old threads.
Aaron,
NASCAR chassis last a looong time if you don't wad 'em up too bad. They make it years of racing and beyond often being recycled to the lower classes!
03-09-2008, 11:15 PM #20
Member
- Feb 2007
- 62
