Results 11 to 13 of 13
    Feb 2008
    835
    Default I LOVE .045 flux core
    I tried .045 flux core and i am hooked. The arc is more stable. I can crank it way up and lay down beads that look like they came from a 1/8" 7018 rod, and I can turn it way down and weld 22g sheet metal easier than .035 FC. I find that .035 punches though sheet metal easier than .045, which is sort of counter intuitive. I like E70T-GS. I think a lot of problems people have with it results from bending their liner. The stuff is thick and stiff and will feed erratically if the liner is at too much of an angle.
    Weaverville, N.C.
    12
    Default Did you run .045 on a MM135 ?
    If so, what roller did you use, the stock one is only rated at .035?
    Feb 2008
    835
    Default I cut a new groove
    It was on the Lincoln pro mig 175. I never use .023 wire in it, so I put it on the lathe and enlarged the slot to fit .045 wire. It ate up 1 side of a carbide insert... must have been tool steel. Don't forget larger liner.
