Page 1 of 3 123 LastLast
Results 1 to 10 of 22
    Dec 2006
    Wartburg,Tn
    575
    Talking High Tech Redneck WELDS
    I was just wondering wat High tech things y`all have welded on . Most high tech thing I ever welded on was a Late model roll cage(frame wat ever y`all want to call it)
    Inferno Forge
    Chris
    Sep 2002
    Clark County, NV
    2,696
    I'd have to think hard about the most high tech one, but one of the more memorable was when I built up and reground the motor shaft of a Ford Model A horn motor.
    May 2007
    Dubuque, IA
    12
    probably a lawn roller haha
    Aug 2006
    Suffield, Ohio
    344
    Paint mixers for the Big Three in Detroit.
    May 2007
    Grande Prairie, Alberta Canada
    729
    Default Expensive Projects
    $350,000.oo+ CDN 2007 Kenworth C-550B Tandem Steer, Tri Drive cab & chassis mounting new Manitec 3577 (35 ton 77 feet tip height) truck mounted picker.
    Next is 2 of 2007 Kenworth C550B Double set-back Tandem Steer, Tandem drive cab & chassis that we are making into gin-pole trucks. Close to the same price as the picker.
    Later,
    Jan 2007
    Midland, Mi.
    313
    I do Aluminum welding and fab as a 2007 sponsor of this Formula SAE car.
    http://www.svsu.edu/clubs/fsae/
    Aug 2006
    near rochester NY
    9,881
    i would have to go with this.
    Sep 2002
    Clark County, NV
    2,696
    Quote Originally Posted by fun4now View Post
    And I thought you were going to show off your wife's bust again!
    Mar 2007
    ****inson ND
    557
    Talking
    I'd have to say this stuff. This company I work at. We make stuff for chemical/petro-chemical processing, water treatment, mining industries, water well industry, etc...... I weld on carbon steel, SS, hastaloy, titanium, etc. I work on everything from wire thats 0.010" dia. to plate several inches thick.
    http://www.weatherford.com/weatherfo.../wft041773.pdf
    http://www.weatherford.com/weatherfo...eens.hcsp?js=1
    Mar 2007
    Oahu, Hawaii
    2,469
    fun4now, when I saw your post, and thought to myself that you should show your hillbilly lift! I busted out laughing when I clicked on your picture!!!
    I'm not late...
    I'm just on Hawaiian Time
