Results 1 to 4 of 4
    May 2007
    106
    Default Holding Aluminum box to weld 24"x10"x144"
    What I am building is a flat botton and top set of pontoons for a small boat with a 40hp outboard. Each toon is 12' long 2' wide and 10" thick and they are ramped up on the bottom forward 3' from 10" thick up to 1" thick on both sides and at the same time will pull around for a full radius front when completed. All of the parts have been designed on autocad and unfolded into cutting patterns and being laser cut at this time. Because of the sides using more than the 12' stock length as they have to wrap around the front there is a filler panel in the front center and at the rear there is a slightly rear facing rake to each toon as this accomodated the bottom sheet having to draw forward about 1/2 an inch as it curled up to meet the top and the front filler panel. I am at struggling with how to hold in position to corner weld this all together. Any advise would be appericiated. If you go to www.craigcat.com there is a boat similar to that which I am building.
    Thanks for any suggestions,
    Doug...
    Mar 2006
    Ocean City, Maryland
    951
    Those are cool looking boats
    Scott
    HMW [Heavy Metal welding]
    May 2007
    106
    Picked up all of the laser cut parts to make up the complete pontoons Got everything out of (3) 4'x12' sheets of 5052 .125 aluminum.
    I guess I will set up a fence along one side on the welding table to crowd the parts together, butt a piece of .125 rod in the corner to slide the bottom up against and set the side panel down on and then put a few tacks along the matching lengths and then begin welding the outside up.
    Mar 2007
    Oahu, Hawaii
    2,469
    WOW COOL!!!!!! Can you show pics on your step by step process???!!!
    Only thing I would be REALLY careful about, is your warpage!!!! As you cross opposite sides on lug nuts putting a tire on your car, I was told to do the same on boats/trailers, so things don't start "pulling" to one side or the other!!! good luck and show us pics!.....NOW!!
    (Can you tell I'm into boats )
    I'm not late...
    I'm just on Hawaiian Time
